Question about Proxxon 37080 THERMOCUT Hot Wire Cutter
My wire will not heat up. Any ideas? - Proxxon 37080 THERMOCUT Hot Wire Cutter
Will a 250 ft of 12/3 extension cord have enough power for a 1500 amp electric heater
I think you mean 1500watt.
I don't think the wire is large enough to be used safely.
Here's a calculator to check your idea.
Online Wire Size Calculators Tables
Jan 31, 2018 | Heating & Cooling
My 2010 Avalanche driver heated seat won't warm up. Lights come on but no heat. Pass side works OK Any ideas?
ck to see if the wires are still connected to the heater under the seat itself , maybe you stuck something under there and broke a wire ,
Mar 19, 2015 | 2010 Chevrolet Avalanche
Hummer h3 2006 - heated seats not working, already checked fuse and all wiring is plugged in, any idea what else could be the problem
check fues 53 heated seat swichs, wire undwe dash rubed against a bracket, i brought to dealer
Jan 23, 2011 | 2006 Hummer H3
Old thermostat wires same color.
Gary, you have not told us if this is just for heat or both heat and air conditioning. I will walk you through a heat only thermostat installation. The two wires you have should connect to R (or RH) and W terminals on the new thermostat. Varify that there are only two wires hooked to the gas valve on the furnace. It is a good idea to hook the red wire to the R terminal.
Jan 08, 2010 | Heating & Cooling
Heat pump goes str8 to heating strips compressor does not run in heat mode pump was manufactured in 03 installed in 07 and has sat dormant till now could it be wired wrong it is a ruud split unit with...
I think that you have the right idea. The wiring is probably wrong. If you can trace the low voltage wires to the air handler. make sure that the Y1 wire on the t-stat is going to Y1 on the hair handler and then to the condenser. The Y2 wire should be going to Y2 on the air handler and probably does not continue out to the condenser. The Y2 should be going to the contacor that brings on your backup heat. It seems like Y1 and Y2 are reversed somewhere.
Nov 14, 2009 | Heating & Cooling
A mouse chewed through a cord and the replacement is $144 any ideas on how to fix it
Any cord can be repaired with a soldering iron and some heat-shrink.
Nov 10, 2009 | Garden
We have a Whirlpool Ultimate Care II gas Dryer that is getting intermittant heat. Sometimes it will heat, sometimes it won't. Iin addition, today it stopped rotating as well. Ideas?
Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
Nov 06, 2009 | Whirlpool GGQ8831L Gas Dryer
Proxxon 37080 THERMOCUT Hot Wire Cutter Logo
65 people viewed this question
Top Proxxon Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Proxxon Measuring Tool and Sensor Expert? Answer questions, earn points and help others
