I'm running two sets of speakers thru a gfs3 powered by a gfa 5300. the main speakers are on 1, the second room pair on 2. the speakers on 2 will only play when the main speakers are engaged. i recently tore the system down to paint the bookcase and i think i may have hoked it back up incorrectly. please advise. todd davis
    Brigadier General:
  • 8,546 Answers
Do you mean Adcom? That detail matters.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFA-5300-Car-Amplifiers-manual/id/582ci558/t/2/
That would mean you're trying to run two rooms with paired mono speakers and a different channel in each room. MMmm, okay.
It's a 2-channel power amp and it isn't really designed for the probable very low imedance you're providing with paired speakers on each terminal. And it has no ability to turn either channel on or off short of denying it a program input on either channel.
Perhaps if you ran one speaker from each channel into each room (impedance permitting), you would have two rooms with traditional 2-channel audio.
Posted on Mar 22, 2011
Fuse
Fuses blow when there is an overload. The overload is often caused by a short-circuited semiconductor, such as a transistor. More often than not it is one or more of the main power amp devices located on a large heat-sink.
Jul 01, 2013 | Adcom GFA-5300 2-Channel Amplifier
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
Adcom 5300 thermal protection light is on right side all fuses are good
Is it actually getting hot? If so, make sure it's getting the required ventilation and that you're not over-driving it. Page 5...
Apr 03, 2011 | Adcom GFA-5300 2-Channel Amplifier
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
Which speaker wires feed which speakers throughout my house?
Since this is a custom install and the wires don't follow a rule the only way to find which is which is to disconnect all the remaining speakers, plug in light bulbs in their places and check every single pair till they all match and their corresponding bulb lights up.
Dec 06, 2009 | Audio Players & Recorders
Adcom GFA-5002 is dead no lights, no anything
Check the Fuse. Unplug the AC first. If you replace the fuse and it blows again, disconnect all speakers, replace the fuse and turn on. If the fuse does not blow, chances are it is a speaker problem, Adcom builds some very solid product, I would suggest pulling the outdoor speakers and testing them.
Depending on what you are using, some outdoor speakers should never be taken out of the living room. If you still have an issue post a comment and I will help some more.
Jun 24, 2009 | Adcom GFA-5002 Amplifier
Can you bridge an adcom GFA-5802 power amp?
Running an amp in bridge mode requires a specific circuit design. It is not possible to combine 2 amps in this fashion.
Dan
Mar 02, 2009 | Adcom GFA-5802 2-Channel Amplifier
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
42 people viewed this question
 Grubhead
Grubhead
