Question about Microsoft Xbox 360 Console
Turned xbox on. tv said "not supported mode". turned off . completely unplugged, re plugged, switched hd/tv switch, no results. what is the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 48 Answers
Try using a xbox 360 HDMI lead, you can buy one here:
http://www.play.com/Games/Xbox360/4-/12361467/Official-Xbox-360-HDMI-AV-Cable/Product.html?_%24ja=tsid:11518'cat:12361467'prd:12361467
Posted on Mar 22, 2011
What do i do if a red ring comes on the xbox
This problem depends on how many red lights there are. The problems can be from a corrupt hard drive, to an overheated console. In this solution, I will mention all problems, and solutions.
1 Red Ring means hardware failure in your Xbox console. It can also mean hard drive corruption. There are multiple solutions to this problem. Turn off your console and unplug every single cord, cable, and memory device on your console. Wait about twenty seconds, and plug everything back in into it's origanal spot, and make sure everything is connected correctly. If the problem still occurs, try unplugging the console's hard drive, then turn on your Xbox 360. If your console then works after this, it could mean your hard drive is corrupt, or broken. Make sure to also disconnect all other memory units out of your console, such as a memory card. If the problem continues, contact Microsoft Support at the following link.
http://www.xbox.com/support/contact
2 Red Rings means that your Xbox 360 console is overheating. Overheating is a common problem with Xbox 360 consoles. Turn off your Xbox console. Make sure it is in a roomy spot, and not near a heated spot. Also make sure it is not on top of a towel, or anyplace cluttered. As seen here,
natesprague6_4.jpg NEVER cool off a Xbox 360 in a refridgerator, or freezer. This may cause further problems to your console.
3 Red Rings means there is a hardware problem, or something wrong with your power supply. To solve this, make sure the color on your power supply is always orange, when your Xbox 360 is off. Also make sure the color is always GREEN when it is on. If it is RED when you turn your Xbox on, try unplugging every cord, cable, and memory device on your console, and plugging it back in about 20 seconds after, and make sure all plugs are connected securely into it's socket. If this does not resolve your issue, contact Microsoft support at the link at the following link,
4 Red Rings indicates that there is no audio/video plugs detected from your AV plug. This is a simple problem to fix. Make sure all plugs are connected firmly into the correct color sockets on your TV. The following colors are the ones that need to be plugged in a Flat Screen TV,
2 Red, 1 Green, 1 Blue, 1 White. As seen here,
natesprague6_5.jpg Although, on a small, old TV, you usually only need to connect the yellow, and white cables. Make sure if you're using an old TV that does not support HD, switch the AV cable to 'TV', if it is switched to 'HD'. If this does not work, you may have to buy a new AV cable.
I hope this helped you, and the Fixya community! Contact me if you're still having trouble!
Jul 02, 2011 | Microsoft Xbox 360 Console
I plug my xbox into the HDMI port and it tells me "Not Supported File" what does this mean?
i wasn't aware that xbox 360 had the ability to plug in with HDMI i use component cables. the problem could be your TV doesn't support HD and if this is an original xbox then it does support HD but the 360 should support it (this is assuming u can even plug it into tv with a HDMI cord)
Jan 15, 2011 | Video Game Consoles & Games
Ok I turnedmy xbox 360 on and it said "Not Supported Mode" on the TV. What does that mean?
av or hd on you lead to tv it has a switch try both settings hope this answers your question
Oct 06, 2010 | Microsoft Xbox 360 Console
I have a sylvania tv i just bought and my brighthouse box works with the sound and picture but my 360 when i plug it in it only has sound and i dont know how to fix it and its on the right station
Is your TV HD supported becoz if not, your AV cable may be trying to get HD TV becoz there is a switch on the bit where it connects into the 360 console try switching it to the other side then turn it off then back on hope this helps :)
Dec 12, 2009 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont work on my Tv now - always been fine before
Hi...
Make sure the switch on the 360 A/V cable is in the right position. Also unplug everything from the unit and plug it all back in again.
From the reading I've done on tech issues the 360 has a lot of temporary issues like that.
Jan 02, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Feb 29, 2008 | Proscan 42LA30H 42 in. LCD Television
Samsung 40 inch lcd mode not supported
i have the same problem as well
wtf?
i used mine for ages then suddenly last night i looked all cell shaded and swirly so i left it over night. i turn it on this morning and get mode not supported. i thought it was my xbox but now i know it is the tv. thanks for at least that much. someone please help
Aug 17, 2007 | Samsung LN-S2651D 26 in. LCD Television
Microsoft Xbox 360 Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
