Question about Logitech 967461-0403-PK Keyboard/Mouse
My logitech keyboard is locked up. I was cleaning the keyboard with a napkin and now it won't work.
    Sergeant:
  • 223 Answers
Thank you for using FixYa
More than likely you have jammed a key and it stuck, try and see if a key is depressed and pull it up with your fingers or a toothpick or popsicle stick, use something that won't scratch it. You might try to turn it upside down and tap on the back with your hand. There may be a piece of paper stuck in the keys and in that case a pair of tweezers might remove it. The key tops will actually pop off and can be pressed back down. If all that does not get it then most keyboard has some screws on the back and can be removed. Look under the legs, sometimes they hide there. If that still does not work, check and see if the cord is plugged in or twisted.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 22, 2011
My logitech keyboard won't work.the mouse is ok
If your keyboard led is not lighting up when you start the computer, there might be a problem with your conection between your keyboard and the port at the back of the computer.
Feb 18, 2012 | Logitech Computers & Internet
My mouse works fine but not the mouse wheel. It won't scroll up and down but when you click the mouse wheel it works fine.I've tried everything, from mouse wheel programs and everything. I change...
Hi, I believe you have to clean your mouse. that's no joke. You have to unscrew it and and clean out al the parts with a toothbrush and tooth-pic.. If that does'nt work. replace mouse with optic mouse.
Good luck.
Jun 10, 2011 | Logitech "Black" LX 300 Cordless Desktop...
My number pad won`t work on my keyboard
Hi there!
Make sure that the num lock light indicator is on otherwise press Num Lock.
If it still fails, I believe you have a defective keyboard. If it is under the warranty, call the manufacturer's support.
Hope this helps!
May 08, 2010 | Logitech 967437-0403 Keyboard
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
S520 Logitech Keyboard keys are sticking
This keyboard is horrible. Several of the keys stick or will not work.
I called customer support which was not very helpful. They told me to take the batteries out of the keyboard then retry the keyboard and if it still did not work return it to the store I bought it from..
I like the set up of the keyboard but? to bad it does not work.
As I am typing this with my old keyboard because I can not use the the s520
Jan 01, 2009 | Logitech S520 Mouse
Problem with caps lock
Is the Keyboard a Multimedia, Logitech or Samsung.
If it is of good quality and under warranty then go for repair it immediately.
In my opinion the key pad getting dust and its inner plate not working. It need to be clean if can be done by opening.
Otherwise, you need to go for buy one.
Regards
ELLIN
Sep 20, 2008 | HP 386209-001 Keyboard
Wireless keyboard locked
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 26, 2008 | Logitech LX 700 9674180101
Logitech 967461-0403-PK Keyboard/Mouse Logo
146 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
