Question about Cameras
Hi. I've just replace the battery of my casio prt 35 but the watch doesn't run. Where is the AC place to make the reset? thanks
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
escapement
  • 2334 Answers
SOURCE: Battery Replacement
Do not lay the tweezers across any contacts as you may damage the watch.
First you need to examine your watch movement and find an AC point (contact). It is embedded on movement. Use an eyeglass, as the writings can be very tiny.
When found, touch an AC point with one arm of tweezers and battery+ with another arm simultaneously.
Some watches needs to do that twice, so, to be sure, do that twice.
If you are not comfortable with tweezers, you can use a thin wire, connecting one end of the wire to AC point and another to battery+.
Each shortcut should last for 3 seconds.
Do not forget to rate, please.
Posted on Jan 27, 2009
escapement
  • 2334 Answers
First you need to examine your watch movement and find an AC point (contact). Use an eyeglass, as the writings can be very tiny.
Posted on Feb 10, 2009
  • 8 Answers
SOURCE: I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
Posted on Feb 28, 2009
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
The battery on my Casio Waveceptor watch - model 4723 - has just been replaced, but the jeweller did not know how to reset it to the correct time. I have downloaded the user operations guide, but the watch...
Your watch probably needs a reset after the battery change.
Take the back off the watch. Examine the movement carefully - you should find a small electrical contact point marked 'AC' (which could be quite small). To perform a reset you will need to temporarily connect 'AC' to the '+' terminal of the battery (basically, the upper side of the battery). If you have some fine point tweezers they are ideal, but a bent paper clip (not a plastic coated one) will do.
Be very careful not the make metal contact with any other part of the movement!
Place one end of the paper clip on the 'AC' contact and, for 3 seconds, place the other end on the battery '+'. As watches sometimes need to be reset twice, there's no harm in repeating the operation while you have the back off the watch.
Once successfully reset, you should have no problem with setup and the watch should behave normally.
Hope this helps.
Aug 29, 2017 | Casio Watches
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
After having battery replaced at a shop, the clock
It looks like daylight saving time (DST). You can reset your watch to turn it off.
If you haven't go any instructions on how to do this, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 20, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I rest my Casio PAG-40 after I replaced the batteries?
You need to shortcut AC point and battery. Take tweezers and touch AC and battery (+) simultaneously. Use an eyeglass to find AC point. It is marked on the movement with letters AC.
Here is the link for easy watch setting:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Apr 04, 2009 | Casio Watches
Replaced battery and it says OPEN
I know the secret that CASIO is hiding behind this thing. If your watch shows "OPEN" then you don't have to go to a CASIO retail store. You don't have to send your watch with money to CASIO or go to an Authorized CASIO Service Center. I know how. Just send me an e-mail to s.duteau@videotron.ca and believe me you'll be happy to know the "SECRET" an get rid of this annoying "OPEN" over with. You want this fix! Than don't wait.
Oct 27, 2008 | Timex T46821 Wrist Watch
Please help me to replace battery on my casio F-91W
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Cameras Logo
78 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
