Question about Holman QCS3-1600B Conveyor Bagel Toaster
Will this toaster operate on a 20 amp curcuit
  • 604 Answers
Look on the back of the unit and see how many watts it draws. use the formula amps = watts divided by volts. to determine how many amps the unit would draw, chance are though, that a 20 amp circuit will be fine, but it does depend on how many and what type ffo other devices are on that same circuit.
Posted on Mar 22, 2011
HOW TO PRINT THE USERS MANUAL FOR THE BLACK & DECKER CTO 6300
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Black & Decker model by clicking the link below.
Black Decker CTO6300 Series Manuals
You can purchase a wide variety of high quality Black & Decker replacement parts for your Black & Decker vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Black%20%26%20Decker
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 09, 2015 | Black & Decker CTO6300 Toaster Oven with...
Voltage change to 120V
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Jul 14, 2013 | Morphy Richards Accents 44744 4 Slice...
User manual of black & decker model mx23pg
Black Decker MY23PG Instructions Manual
Ava B.
Feb 27, 2013 | Black & Decker CTO6300 Toaster Oven with...
Dualit toaster short circuit
Is not an open curcuit but a short curcuit. Means that one of the wire conections you have made is either contact with toasters body or one contact is touching with other contact. So you need to have all contacts of the toaster from the bottom side to see if their are clear to each other or from the toasters body
Oct 09, 2012 | Dualit 20084 2Slice Toaster
1995 gmc safari van. The a/c (20 amp fuse) keeps blowing. Sometimes even at startup.
WEll, something is amock, use a curcuit breaker, self resetting, and chase it down. Consider an amp draw reading on the clutch.....
Sep 08, 2010 | 1995 GMC Safari
Need to find out how many amps fuse DeLonghi CF210 needs
Yes. This machine will work on a 120v 13 amp socket.
13 is an odd number. U.S. household 120volt circuits are either 15 or 20 amps. I assume you are going to plug this into a 15 amp circuit, or you are not in the U.S. -- is that correct?
The circuit should have nothing else running on it of any significance -- lights should be okay -- vacuums, toasters, etc. would pull too much current and trip the breaker if these are operated simultaneously with the A/C.
May 30, 2009 | DeLonghi De'Longhi CF210 Pinguino Homecool...
Holman QCS3-1600B Conveyor Bagel Toaster Logo
152 people viewed this question
Top Holman Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Holman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
