Question about Dell Dimension 2400 PC Desktop
Lexmark2600 installed after lexmark1200. disinstalled old softwarde, installed new 2600 SW - nothing appears in Printer?fax window tried to 'add printer' - says operation not completed - printer can't start spool - tried starting this, no joy spool
When Inserting Cd,After Green Light Stops On Your Drive Letting You Know That Your Disc Is Read,Hit START-MYCOMPUTER-Double Click DVD-DRIVE (E) Should Say 2600Series(E)
Posted on Nov 24, 2008
No puedo scanear
Posted on Oct 18, 2008
I have the same problem.
Posted on Oct 11, 2008
LOST INSTRUCT MANUAL. HOW DO I INSTALL NEW INK EPSON SX425W?
Do the below steps.
First of all you have to prepare your printer drivers. This must be CD or DVD disc which you already have from printer manufacturer or supplier. If don"t you can check for the latest drivers on manufacturer website.
Now let"s start. Click on Start button, next Control Panel and the window shown below will appear at the screen. Please note the window below is in new Windows XP style. If you like old classic style of Control panel click on top left in task pane. Next click on Printers and Other Hardware Icon or Printer and Faxes in classic view.
1268_control_panel.jpg Now you can select Add printer... from Pick a task section or Printer and Faxes icon to continue with printer installation If you select Printer and Faxes icon next click on top left in Printer Tasks and on Add Printer task.
1269_control_panel_printer.jpg When to screen appear Welcome to the Add Pinter Wizard. Please read the note and skip the wizard if your printer is connected to USB or any other Plug & Play port. If not click on Next.
1270_control_panel_add_printer_wizard.jpg Now select Local printer attached to this computer for printer connected directly to your PC or select A network printer, or a printer attached to another computer for printer connected to your office or home network. Automatically detect and install my Plug and Play printer option needs to be selected when you don"t have any information about your printer model and drivers. Click on Next.
1271_control_panel_add_printer_wizard1.jpg Next select Printer Port from drop-down menu where the printer is connected or Create a new port. Click Next.
1272_control_panel_add_printer_wizard2.jpg Now from the left list select manufacturer of your printer, and next click in right list on Printer model which you want to install. Best result you can get if you have correct and updated Printer drivers on CD or DVD disc and click on Have Disc button to select this drivers. When correct drivers are selected Windows will install the files and you will get new icon in Printer and Faxes section in Control Panel.
1273_control_panel_add_printer_wizard3.jpg When installation of drivers complete you can right click on Printer icon and select Properties from menu to setup the features and settings of your printer
Now you can give print.Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 22, 2011 | Office Equipment & Supplies
My HP 2610 All in One printer will not print anything from my computer. Have uninstalled and reinstalled software by still will not communicate.
1. Check to see if another printer that was installed previously is set as a default printer in the printer and fax icon in the control panel.
If you have one there right click and delete.
Add your new printer or do a search for new printer and locate your printer and install it.
Windows "help" will guide you through the setup or your instruction manual that came with the printer.
Apr 19, 2010 | HP Inkjet 2600 Printer
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
Need to fax docs w/ a Dell 942 all-in-one print-fax-copy-scan.
To install and configure the Microsoft® Fax software:Click the Start button.
Click the Control Panel icon.
Double-click the Add or Remove Programs icon.
Click the Add/Remove Windows Components icon on the left side of the Add or Remove Programs window.
When the Windows Components Wizard window appears, click to place a check in the box next to the Fax Services listing.
Click the Next button.
When the Files Needed window appears, insert the Windows® XP CD into the CD-ROM drive.
From the Copy files from: drop-down button, select the drive-letter that represents your CD-ROM drive.
Click the OK button. to automatically open and close several installation windows.
When the Installation Complete window appears, click the Finish button.
Close the Add or Remove Programs window.
Click the Start button, point to All Programs, point to Accessories, point to Communications, and then point to Fax.
Click Fax Console.
When the Welcome to Fax Configuration window appears, click the Next button.
Enter any appropriate information in the fields provided.
Select your data/fax modem from the drop-down button located below the Please select the fax device listing.
Click the Manual answer button or Automatically answer after (specify number of rings) button.
Click to select the Enable Receive listing.
 Note:
  By selecting the Enable Receive check box, you can receive faxes. However, selecting this option may cause the computer modem to answer all incoming phone calls in which you may not receive voice mail.
Enter your TSID (Transmitting Subscriber Identification) information in the field provided.
Enter the CSID (Called Subscriber Identification) information in the field provided.
When the Routing Options screen appears, click to select the Print it on check box if you want each received fax to be automatically printed. If selected, use the drop-down menu to the right of this field to select the Dell AIO Printer to print the received fax. Your printer must be on and connected to your computer in order to automatically print faxes.
To create an archive copy of each fax, click to select the Store a copy in a folder check box.
Click the Browse button to select the desired archive location.
Click the Next button to display the Configuration Summary list.
Confirm your configuration settings are correct, and then click the Finish button.
You are now ready to send or receive faxes.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&dn=1091795
Nov 14, 2009 | Office Equipment & Supplies
How do I install an hp printer 2110 without a cd onto windows vista computer?
go to www.hp.com
>click on support and drivers tab
>tick on the box that says download sw and drivers
>type in your printer model number then click go
>it will open new window
>select your operating system (vista)
>select full feature sw and drivers
>downloaqd and save this in your pc
>after downloading run the sw and install it on oyur system
Sep 28, 2009 | HP DeskJet F380 All-In-One Printer
LEXMARK 2600.
If there is indication, follows to avoid her cause jam papers is defined sensor, their three
Turn your attention. The First on entering the sheet the second on passing and the third on output. If sensor blazes,signifies you test each. One for others.Most often untrue take out stuck of paper and this can be on output. Can be, when the list has stuck and her(its) extract, break the sensor. Check his(its) condition. Nothing else.. You manage! See the sensor and include- switch off the printer. Good luck!
Jun 07, 2009 | Office Equipment & Supplies
Communication problem printer lexmark2600
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 12, 2009 | Lexmark X4530 InkJet Printer
Fax
Hi all, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Aug 04, 2008 | HP Officejet 4110 All-In-One InkJet...
HP 2700 serie all-in-one printer
my hp all in one 2700 will not sent a fax my grand son had his hand on my machine it now says that image on fax send report is set to off . how do i set it to on
Jul 10, 2008 | HP Photosmart 2610 All-In-One InkJet...
Problems installing a printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
Dell Dimension 2400 PC Desktop Logo
52 people viewed this question
Alun Cox
