Question about Hoover H130E Front Load Washer
Hoover visionHD 8 kg 1400 spin
The machine will fill, spin but will not drain the water away. have checked the outlet pipe and the sink trap but these are clear.
  • Hoover Master
  • 19,396 Answers
My hoover optima 7 kg 1400 aaa will not go into the spin mode ?
drain pump needs to be replaced, washer needs to be empty then will spin. please comment.
Dec 03, 2014 | Hoover Washing Machines
Candy 1400 aaa fills water but that is all it does
Simply try the old off at the plug, wait 10 mins then on again. Then try looking where your machine has access to the 'flap'. Basically, ours did that, I opened flap bottom right, where the muck/hairs/hair clips/pencils etc etc have all accumulated in the years of use. Clean it all out. Our machine apparently refused to spin / turn whilst bunged up with rubbish. Cleaned it out, turned back on and selected a "spin dry" only cycle and left it. Also, there's a pipe that outlets the water - usually directed into your sink drainage pipes. Check this isn't going up-hill. What I mean is, the draining water will pump mildly upwards sloping but I found ours was too steep thus not draining thus it wont spin. Not an engineer just had many issues similar with our cheapo Beko machine.
Oct 12, 2014 | Washing Machines
Drum fill with water
If your machine outlet pipe is connected to the sink trap (many are these days) it could simply be that water from the sink is draining into the washer if it is connected like this ensure that where the outlet pipe leaves the the trap it goes up and does not run level or down if the water in the is dirty this is the problem failing this water vavles are passing water when the machine is off
Mar 03, 2014 | Whirlpool 3.5 Cu. Ft. White Front Load...
Hoover nexus 8 1400 washing machine not spinning
if u cant unscrew it somethings jammed in it ,force it or pull the pump houseing apart
Jan 17, 2013 | Hoover Washing Machines
Frigidaire top loader drains water from underneath
You may have a split in a outlet pipe or a pipe has come off. If it's only leaking when it is emptying I would suggest it's probably a pipe after the pump and one that is higher then the level of water that is in the machine as otherwise the water would siphon out all the time.
Has the outlet hose been extended and have a coupling where it joins?
Dec 28, 2012 | Frigidaire FWS833A Top Load Washer
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washer will not drain or spin with pipe in specific washer drain but will if placed in the sink We have moved house and the new house has the usual pipework behind the washer. The machine will fill and...
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Nov 18, 2009 | Hoover Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
My brand new Lg front load washer fills with water after the completion of a full wash/rinse cycle has finished and the machine is turned off.
can be
either
inlet valve leaking. turn off water and see if it still fills
or
if drain is plumbed in to a spigot off the sink trap, every time you empty sink, some of the water goes down the drain pipe. to cure in this case, take the drain pipe as high as possible up under the sink in a swan neck
Oct 18, 2008 | LG Washing Machines
Hoover H130E Front Load Washer Logo
322 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
