Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
How to replace battery in the Schiller AT-2 light EKG machine
    Problem Solver:
  • 17 Answers
The battery in the Schiller AT2 is as 12 volt 2.2 AH battery commonly available from R&d batteries, there part number is 5515. To replace it requires disasemble of the unit. Note that you should never disasemble this unit while it is plugged in. Also there are several cable that attach teh top housing to the PC board, and if you are not dillagent about not pulling these vcables apart while disasembling the unit, you can do expensive damage. Bearing that in mind, I would proceed as follows:Turn the unit upside down on top of a towed or other soft surcace to prevent scratching the soft plastic of the upper housing. around the perimeter of the case you will see several screws, i think 8 if i remember correctly. Repmove them and place them in a cup or other container. Grip the top and bottem cases together firmly and flip teh unit back upright. GENTLY lift up the top housing, and VERY CAREFULLY slide it about 3 or so inches to the left. This will expose the battery. just lift it out and replace it with the new one.Take care to reconnect the wires in the same position as teh original battery. Mis wiring the battery will cost you hundreds of dollars. The wires connect via slide on spade connectors. grip them by the connector itself(not the wire going into it) and gently rock it side to side while pulling, it will eventually come off the battery terminal. Resemble the unit in the reverse order. Plug the unit in and fully check it prior to re-installing the screws in the bottom of the unit in case you pulled a cable loose. As an alternative, you can detach the cables from the pc board and place the top cover to the side while replacing the battery, but be VERY careful with the cables. I recommend that you have a qualified individual preform this replacement for you. the cove being removed exposes high voltage, and also presents the risk of expensive damage to your unit.
Posted on Dec 05, 2011
I HAVE A SCHILLER ATP-2 PLUS EKG SYSTEM. ITS PLUGGED INTO WALL. IT BEGINS TO PRINT AND SHUTS OFF. I TRY TO SAVE IT BUT WHEN I DO "ALT" "S" IT SAYS "NO DATA".
The battery is faulty. You have to replace the battery.
If you wish to get some details about Schiller ECG machine repair then check the following link.
http://electro-medical.blogspot.com/
Jul 06, 2016 | Schiller Medical
The ekg machine light of filter is flickering and when printing only prints one line out of three appears as if no ink
HI,
Here i added a link which will help you to rectify the problem. Its seems to be the battery of your ECG machine is faulty.
Schiller AT 1 Support
Jun 25, 2012 | Schiller Welch Allyn Cardiovit At 2...
The Schiller AT-1 is not printing, when the patiente cable is conected the unit start to print and stop after 1 second and turn off. If I disconec the cable the unit keep printing
The Schiller AT1 is a battery powered unit. A common symptom of weak/defective battery's is that it will stop printing after 1-2 seconds of run. As to whether the patient cable effects this, I honestly don't know, It really shouldn't, baring some very weird internal short in the cable. The battery in the AT1 is beyond the average user to safely replace. Before anything else insure that the AC indicator light illuminates when the unit is plugged in. If not, you device might have a defective power supply. In either case, the unit needs repair in a Qualified shop.
Oct 28, 2011 | Schiller Welch Allyn Cardiovit At 2...
The machine cuts off power as it tries to print the ekg
hi,
Change the battery, will solve your problem. Its a 12v battery. For replacing the battery you have to open the ecg machine by removing the screws at its bottom.
ok
Feb 26, 2011 | Schiller Welch Allyn Cardiovit At 2...
Schiller cardiovit at-2 we can only get 3\4 of a ekg it stops
hi,
ur Schiller at 2 has problem with its battery. just replace the same. its a12v battery.
also clean the paper sensor Whit an ear bud (do not use any chemical use only ear bud). u can see the paper sensor on the side of printer head. a square black portion.
ok
Jan 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
It will print 3\4 of the ekg it stops !!
hi,
also clean the paper sensor With an ear bud (do not use any chemical use only ear bud). u can see the paper sensor on the side of printer head. a small square black portion.
ok
Can run half an ekg and then it stops - what gives?
hi,
replace the 12v battery inside the machine., and then try.
ok
Oct 11, 2010 | Schiller Welch Allyn Cardiovit At 2...
I have Schiller AT-2 Plus, i need instruction manual,or guide me how to chnage date and time,hospital name.
i want to configure my Schiller at-2 plus ecg machine from dutch to english and 3channel to 6channel
Mar 17, 2010 | Schiller Welch Allyn Cardiovit At 2...
The printer stop when you request to print out and in auto mode print only seconds time
check to see if the power light goes off when that happens. it sounds like the battery will need to be replaced.
wats@mesasales.com. www.overstockme.com. Jeff Watson
Nov 06, 2009 | Schiller Welch Allyn Cardiovit At 2...
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
1,046 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you a Schiller Medical Expert? Answer questions, earn points and help others
