Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water pan is filling up and overflowing. There is a white thing that is over it and it is leaking. Do not know how to get it to stop.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Your water filter and possibly the housing will need to be replaced.
Kelly
Posted on Mar 22, 2011
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
When i turned off water supply it stopped leaking
there should be a shut off switch that might be broken or blocked in the open position when the water gets to the correct level this switch should stop the water flow. if it is broken or jammed the water will keep flowing. I hope this was useful.
May 28, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a miele G841 dishwasher and the saftey pan is always filling up with water and then a intake - drain error code comes up and the dishwasher will not allow water to enter for rinse until I drain...
Hi dear.If you are handy enough,that's what you can check to make a solution for yourself.Goodluck.
Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?)
3. Check overflow float switch B8/3 for continuity and correct operation.
4. Carefully dry all electrical components in the drip pan area.
Cause:
Float switch defective.
Remedy:
Replace overflow float switch B8/3.
I hope that helps.Thanks.
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
We are getting an overflow of water in the pan in the bottom of the refrig. What causes that and can the pan be removed to empty?
This may sound strange, but the cause of your problem may be your icemaker. The fill tube may be leaking before it gets to the ice maker and causing the pan uner the fridge to fill up too much. try turning your ice maker off for a few days and see if the issue stops. Or you can see if the tube is loose or iced up. If it is iced up, you may have a bad water valve. If you need more assistance, let me know. Hope this helps!
Dec 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Water is leaking under fridge. The pan keeps filling up and overflowing
On some models, when the water dispenser is clogged the water will bypass to the drain pan. The water from the defrosted freezer also drips to the pan but it shouldn't fill it under normal conditions. Try to see where the water is coming from.
Sep 20, 2009 | GE Refrigerators
Is a Kenmore Elite Upright Frost-Free Freezer supposed to have water leaking from underneath it? Would this be the water accumulating from the "defrost cycle" on it?
Is the drain pan underneath overflowing? If so the water filter may be clogged and the water leaking past it to the pan. The normal amount of water from the defrost cycle shouldn't fill it up. The condenser fan usually evaporates the water by blowing the warm air on the pan.
There could be a leak because or the defrost drain being stopped up but this usually comes out the bottom of the freezer door.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 16, 2009 | Freezers
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
WHERE IS THE WATER COMING FROM UNDER MY FRIDGE?
very odd that there would be an influx of water to that pan, especcially enough to overflow it. a bit of a pain in the butt to remove that pan, try soaking some water out if it. and see if you can see where water coming from, id be willing to bet that the water filter housing right next to it is leaking and happens to be filling your drip pan, did you replace water filter recently?? perhaps its not seated properly.(regardless removing the water filter should stop the leak)
Mar 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
Asko 1605 cycle stopped, pump keeps running, water pumps out but will not progress to the rinse and wash cycles. Timmer will turn and detergen dispenser will open. Pump keeps running
Thanks my Asko did the same and tilted it forward, drained excess on the floor, even though I thought i'd bailed the whole lot and woolaa fixed - thanks x
Oct 18, 2007 | Dishwashers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
