Question about Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive
Hi, my macbook stopped reading my HD and I was wondering how I can get my files off the HD and back them up on my computer
  • 72 Answers
First determine if problem is with your macbook or the drive. Does the drive work on any other computers? If not, then the problem is either the drive or the Acomdata enclosure holding the drive. You'll need to get a usb HDD dock, extract the harddrive from your Acomdata drive and plug the drive into the HDD dock. If your mac is still unable to read the drive, the drive itself is probably not working anymore. If you're a novice and have never attempted data recovery before, I would recommend a data recovery service if it is important that you recover your files. If the the problem is with the drive, there may still be a good chance your files can be recovered but only if you know what you're doing. You don't want to run the risk of ruining that chance and attempt this yourself if you don't have the proper tools or knowledge.
Posted on Mar 22, 2011
    New Friend:
  • 19 Answers
Unplug the hard drive and connect it with some other supportable mac machine and install this tool to recover data from macbook hard drive .After successful recovery save the data to a different location.Its a demo version and the full version will be fruitful. It worked well for me..Try it...
Posted on Jan 31, 2013
Reset button
Hi Terry, Are you wanting to set your computer back?
If so.
You need to boot the system to the Recovery HD. Hold down Command+r key at startup. Open Disk Utility and erase the Macintosh HD. Exit out of DU and select Reinstall Mac OS X. Select Macintosh HD as the place to install to and wait for OS to be downloaded from the net. The computer will restart when the download is finshed and the install will start.
Mar 06, 2015 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
My personal Macbook pro died, but I did have a Time Machine backup. I have a new iMac that I would like to use as a family computer. I would like to transfer some files to the new computer (and set-up a...
The best approaches is to buy a 2.5" usb sata drive case. Remove the hard drive on the macbook to get back your files and folder on the new imac. Use the drive afterward for time machine
Aug 03, 2013 | Apple iMac Computers & Internet
I restored my computer's HD using LaCie. Now, my Macbook won't boot us using it's own HD, just LaCie
Hi SuzanneHow did you do the install? It's important that you do the correct procedure. First you should have installed the OS from the disc thaty came with your MacBook. It would have then asked you how you wanted to procede. One of the options is to restore from a back-up or from another drive.
You pick the Lacie and let it do iots stuff. As a rule, when that finishes the machine restarts from the new drive.
What you can do to check is shut the machine down. Hold down the Option key (alt key) and then press the power button to start it up again - don't let go of the option key. After one or two moments you will get a grey screen with a two icons. One will be your HD and the other will be the LaCie. You then choose which onwe to start from and that should be that. If you only get the Lacie showing up then it measn that you do not have a system on the internal HD and that it needs to be restored from the CD/DVD.
Let us know what happens.
Mar 03, 2013 | Apple MacBook Pro Laptop Computer with...
Hi, guys. Just received your Iomega eGo Helium 500 GB external hard drive and successfully backed up the HD on my MacBook Pro. My question is whether your HD can be formatted/configured so I can also...
Yes all external drives can be formatted but formatting will always wipe off everything on it. If you want to format it you can right click on it when it appears in Windows Explorer. You are usually offered the choice of file system FAT or NTFS. FAT is limited to a file size of about 4 GB, so usually choose NTFS, I am presuming you are talking Windows system. Then you would have to copy your files to it once again.
Nov 02, 2017 | Iomega 500GB eGo Helium Portable 500 GB...
LaCie 200GB HD is now ''read-only''. Recommends reformatting.
>> my computer could not repair the hard drive
It seems that the disk-drive is "dying", and the "table of contents" on the hard-drive has become corrupted, and automated attempts to "repair" the corruption have failed.
>> the hd is being offered with limited functionality, basically read-only.
Yes. Take this as a "hint" that the disk-drive is about to "die".
>> It recommends that I back-up the info elsewhere
Good advice. Take the advice.
>> and reformat.
This may help -- it will identify any "bad" spots on the hard-drive, and will either permanently avoid using those bad spots, or it will allocate a "spare" track on the drive to be used as a substitute for the "bad" area.
However, even after doing this, I would not "trust" the device to be a "reliable" backup for my important files. Like a well-used chalk-board in a classroom, the disk is getting "worn-out".
If it's still under warranty, exercise the warranty.
If the warranty has expired, replace it.
Apr 22, 2009 | LaCie Computers & Internet
Is it possible to undelete files on a Sony HDR-SR1 Camcorder?
The answer is YES. Power off your camcorder, take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your files safely! Regards
Dec 19, 2008 | Sony Handycam HDR-SR1 HD Camcorder
LaCie Design by F. A. Porsche 160 GB not showing on MacBook Pro
The first thing that I would do is try connecting the drive to different USB Ports. If that does not work see if there is any software that came with the drive or that you can download from the internet that you might need to get the drive working. Next I would connect it to a different computer to see if it works that way. If it works when connected to a different computer I would at least get the files on to that computer and transfer them to the computer that you need them on using a network connection, a CD/DVD, or a USB thumb drive.
Nov 07, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive Logo
169 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
