Question about Maytag Washing Machines
Lost the manual for my maytag performa washer A206. How do I access the drive and pump belts ?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The A206 is an old style washer. They are accessed by tipping the machine back against the wall. They are easilty replaced, come as a set...replace them both!
Kelly
Posted on Mar 22, 2011
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
My maytag performa top loading washer will not spin or drain, what could be the problem and how do i fix it?
HELLO THERE
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Aug 20, 2010 | Maytag Performa PAV2200
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Washing machine
Most Maytag washers have 2 belts - looks like the drive belt is not good anymore and needs to be replaced.
Aug 18, 2009 | Maytag Performa LAT2500A
Performa washer smoking and smell of burnt plastic
It could be the pump or the motor overheating.
Remove rear panel, and run washer through a rinse and spin cycle.
After it has finished, unplug the washer, and feel the pump and the motor, they should be relatively cool to the touch.
If either the motor or pump feel hot, then that is probably the cause of the problem.
Also check for a worn or slipping drive belt.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Maytag Washing Machines
Noise when washer is in spin/rinse mode
most likely its the pump this is a simple repair just lean the machine back and remove the belt. if this machine has an access cover on rear remove it and disconcet the two hoses from the drain pump remove the three screws holding the pump in with a 3/8 scocket install new pump reconect hoses put back cover on put belt on and your done if no access panell on the rear just pop the top with a stiff putty knife at the front corners remove the front cover and the pump is right there on the right front corner remove it the same as rear put new pump on put cover on close top and your done
Jan 20, 2009 | Maytag Washing Machines
My maytag performa model number Pav 3200 IS SMOKING
Pump locked up Tip the washer over and take the belt off. try to turn the pump both direction. look for seperation in pump seal. Very easy to replace. Tools needed 3/8th nut driver. water pump pliers. pump is 30 bucks
Dec 17, 2008 | Maytag Performa PAV3200
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Washing Machines Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
