Hello, I have a set of 4 of the Pyle PWRC82 Dual Channel 8" in ceiling speakers that I want to use with an older Panasonic 200w stereo system for my garage. The output impedance for the speaker hookup says 8 ohms to 16 ohms. I have wired the ceiling with 4 indivisual sets of 16 guage speaker wire ( one for each speaker +&- ). I'm in need of a simple diagram or instructions to connect my stereo to these speakers, as not to blow them up or damage the speakers or the stereo, as I'm not familiar with hooking up Dual Channel Speakers. Thank You Frank Licek
  • frank122560 Mar 25, 2011
    I,m going to wire them up in series to raise the impedance to match the amp, as I have blown 1 speaker already.
    Thanks for the help.
    Frank
  • 3,400 Answers
Hook them up conventionally 2 speakers to your right side of amp/receiver and the other 2 to left. (2 positive to rt side of receiver, 2 grounds to grounds rt side, left the same... you won't blow those speakers.
Posted on Mar 22, 2011
What is best way to wire speakers to 70V amplifier
If you are attempting to connect standard 4 ohm or 8 ohm speakers to a 70v amplifier, you will need to purchase "MATCHING TRANSFORMERS" for the speakers. These matching transformers will be available from the manufacturer of the 70v amplifier.
Apr 20, 2015 | Pyle 6.5" Dual In-Ceiling Speaker System
I need help setting-up my sound system with following equipment listed below:
Wow....what you have here is a total system design. I really feel you need to get a professional in your area to help you out. There has to be a buddy of yours that knows enough to help out. There are just way too many variables in this that are unanswered. Amp channels, amp output, speaker impedance, other equipment needing balanced or unbalanced, type of jacks, stereo/mono, length of runs, power requirements. It would take me hours to look up the specs of your equip, a couple hours to design and hours of questions back and forth. At best if you let me know where you are I may be able to set you up with someone local to your area.
Nov 14, 2013 | Car Audio & Video
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
Speaker produces sound even when the zone is off
Since the Pyle speaker is a 4 ohm device, it's likely that when you have other zones on, the change in the impedance will affect the volume. Check to see what impedance your other speakers are (standard is usually 8 ohm), and if your tuner has impedance matching for your zones. If it does not, that's most likely your issue. You could get an impedance matching transformer at Radio Shack to resolve this issue. Please rate my solution, thanks.
Apr 17, 2009 | Pyle PWRC82 Main / Stereo Speaker
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
56 people viewed this question
 Grubhead
Grubhead
