Question about Health & Beauty
Sunbeean BP meter 7652 wil not pump up and hold pressure.
    Brigadier General:
  • 3,513 Answers
Hi
There is probably a problem in your motor inside the body of the machine. Either the pump is not generating air or the device is not properly clean. Do calibrate the device using the Service manual given on the purchase of device.
Please check the bellow link for more information:-
http://www.ehow.com/how_5139659_troubleshoot-blood-pressure-monitor.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 22, 2011
Scale of blood pressures at ages 70 to 80?
This can vary quite a bit as your plumbing is not what it used to be. It is now recognized that increasing BP in older people is in fact not normal or desirable, and should be treated. However authorities say that aggressive treatment and large decreases in BP may be just as risky. BP in older people is always worth checking.
Still, since we are talking about a range of persons, we have to look up averages. If the reading is about 140/90 or above you should ask the doctor about it, but the doc may consider this is OK,
If it is 130-140 over 80-90 you are doing very well. If much less, ask the doctor.
Now a longer record at different times will tell the doctor a great deal more, so you might want to get a home BP meter, have the doc check it, and keep a record of random readings. I have one, I'm an old f**t, I take 2 tablets, and the meter has been very informative.
Feb 16, 2017 | Health & Beauty
I have a manual bp kit the needle wil not move past 80 please help me fix this
I doubt it can be fixed . perhaps just buy a new one .
May 19, 2015 | Health & Beauty
Mbo osc compact 1020
Sorry, I've been using an ADVOCATE meter since my heart attack in 11/2012. Mine is a wrist monitor and I've taken it to my PCP and my Cardiologist's offices to compare results, and I am quite happy with this wrist monitor. I can fit it into my lunch bag and take my BP during my work-day (I've also got a tiny Glucose meter that fits into the cusp of this BP meter - I take my BP & BS 3x daily). Good luck.
Jul 31, 2014 | Health & Beauty
The rubber pump on the Sunbeam BP Monitor we have now has a hole on the ruber pump. Super glue did not hold it together. Is there anything we can do w/o buying another Digital B/P Meter, Model 7622? A...
http://www.amazon.com/Balls-Inflation-Accessories-Doctor-Repair/dp/B000LXYJAS
I believe you will need something like that ..It is used normally for fixing holes in sports balls ..and if it works for balls under pressure ..it will work on the pump as well...I think it is a synthetic rubber solution ..that adheres on the original one ...(I think it has to be inserted in the interior ..side..with a syringe ...) My advice is to detach the pump before insert the solution ..(read the user guide) ..and this way you should be able to blow air inside from the end you detached ..and seal it proper in the hole..
Jul 25, 2011 | Sunbeam Health & Beauty
Looking for replacement arm cuff for my sunbeam blood pressure monitor model 7652
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
http://www.foodsaver.com/manuals/HAH/Manuals/7652.pdf
Good Luck
May 24, 2010 | Sunbeam Health & Beauty
Centrios wrist BP monitor, model 10A03. When pu...
centrios wrist monitor works to inflate and deflate monitor but displays "1" instead of blood pressure reading
May 21, 2010 | Health & Beauty
Suddenly showing higher reading
the damage to sleeve might not b the exact reason all v need in a spigmomanometer is pressure . it might b a problem internally just chek that once with a biomedical engeneer if the meter is perfect immidiatly care ur health
Mar 15, 2009 | Health & Beauty
WHAT WOULD BE CONSIDERED LOW BLOOD PRESSURE?IS IT NORMAL FOR MY TOP NUMBER TO CHANGE FROM 104 TO 129 IN ABOUT 5 MINUTES?
There are standard methods for measuring BP. One should be seated on chair, feet on ground, leaned back, relaxed for at least 5 minutes, at least 2 hrs after a meal, .... then repeating this procedure several times daily, and averaging will provide some ave daily BP value.
Using this procedure for hourly BP measures, one can adjust times and doses of BP medicines taken daily.
Nov 12, 2008 | Omron Healthcare 2007 Hem 711DLX Automatic...
Health & Beauty Logo
85 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
