The bearings have gone, how do i replace them ?
  • Marvin
    Marvin Mar 22, 2011
    You can start by giving us the make and model number of the washer.
    Sergeant:
    Champion:
  • 202 Answers
You can't ....its part of the Tub assembly you need to buy the inner and outter tub assembly
Posted on Mar 22, 2011
How to replace 2007 streetglide transmission output shaft bearing. Can it be done from thr left side?
Never had a transmission output shaft (the bearing that supports the belt pulley shaft) fail. Are you sure this bearing is gone? The bearing that usually fails is the clutch mainshaft bearing that is mounted on the inner primary casing and causes a noise that can be stopped by pulling in the clutch and putting it in gear. If this is the case, then the bearing is gone. It is replaced by removing all component from left side engine. No need to go near the transmission.
Feb 16, 2014 | 2007 Harley Davidson FLHX Street Glide
Replace belt tensioner
Check with autozone website they it will show you if the bearing is replaceable and how
Feb 03, 2013 | 1994 Land Rover Discovery
My hot point wma bearing is gone. Where to buy spare ones.
Depends where you live here in England I buy from hotpoint.however its quite a big job to do also you may find this models bearings are sold on as half drum,you need to buy he half drum with bearings fitted to replace and costs parts approx 70.pounds..hope this helps
Jul 01, 2012 | Washing Machines
Strut bearing keeps going bad ,WHAT IS CAUSING IT? SECOND ONE GONE BAD
If you just replaced bearing & not plate & strut &/or spring these are what are causing it to wear out. Always replace bearing plates, struts & springs in pairs. Then right away get 4 wheel alignment.
Jan 17, 2011 | 2001 Honda Odyssey
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Loud roaring noise in rear tires
Chances are that your wheel bearing has gone bad and will need to be replaced. Auto Zone will have the part and tools you'll need to replace the wheel bearing with step by step instructions for you to get the job done. Good luck and keep me posted, be glad to know your car is running 10%% again soon
Feb 16, 2010 | 2003 Toyota Camry
My machine bangs on a full spin.is it the drum bearing?its a hotpointwf340g.how do you replace bearing or fix this problem.
If it bangs it doesn't necessarily mean it is the bearing that is gone. It could just be a imbalance on the load inside. To check if bearings are gone open the door and at the rear of the door seal nearest the inner drum use your fingers to hold down the outer drum, will be at rear edge of seal, now use your other hand at the top pressing the inner drum edge and now press down on outer drum and up on inner drum. If bearings are gone her will be a lot of movement between the two. If no real evident movement then you can feel pretty sure it's not the bearings. Check suspension for signs of wear and check for loose weight block, also check for loose components inside the shell that may be hitting the outer drum. Could also be that the machine is unbalanced if the feet adjusters are not properly adjusted to level the machine correctly.
Feb 07, 2010 | Washing Machines
Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
The engine makes a funny noise and the brushes make sparks.
Hi
The bearings are not replaceable. If the bearings have gone you need to replace the complete motor
Mar 09, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
