Question about Samsung WF328AA Front Load Washer
Water drains out automatically from samsung fully auto machine top loading
This is what you can do;
1. there should be a holder at the back of the machine to put the hose higher than the water level to avoid draining by gravitation.
2. put the inlet of the hose to a drainage
3. let the process start to wash. this machines are equipped with internal pump to push water out to proceed to the next process. once drained, the process starts to rinse and spin.
hope this is clear.
Jonathan
Posted on Aug 02, 2012
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Make sure your drsain hose is higher than the water level and not sealed in the drain line in your home. Also, make certain it is not sitting in the water in the drain line as well....it must have air to prevent siphoning.
Kelly
Posted on Mar 22, 2011
Whirlpool whitemagic pro 700h
The model no is Whirpool whitemagic pro 700H fully automatic top load
Dec 19, 2013 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Fully automatic washing machine top loading model water is getting drained out automatically
Look at the height of the discharge hose. It must be run higher than the machine, or all water can run out.
Jun 08, 2011 | Whirlpool Washing Machines
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
Hi Unable to drain the water from my fully automatic top loading samsung washing maching. (Model - WA80TAL). How to do it. Regards Uday Sundar
You can take the hose that goes to the drain and lay it down. but when you do that the water will run out the hose so make sure it goes outside or into a floor drain. You pump is either jammed or broken or the solenoid that turns it on is out.
Sep 22, 2010 | Samsung Washing Machines
I need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
May 04, 2009 | Washing Machines
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Samsung WF328AA Front Load Washer Logo
130 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
