Question about Honeywell Heating & Cooling
Honeywell th5000 thermostat will not change cooling temp setting below 72.
4 Suggested Answers
mattozan
  • 555 Answers
SOURCE: The builder of my house
What is the model # of this Honeywell thermostat?
Posted on Apr 25, 2008
  • 116 Answers
SOURCE: kids reset temperature and now it won't let me set cool to below 70F
hold the button on left an the up button in for five seconds this will enter program mode hit next until 70 comes on and use up dn arrows to set temp info on this stat is on their web site sorry dont have book with me
Posted on May 09, 2009
  • 57 Answers
SOURCE: My Honeywell programmable thermostat reads
I think you need to charge freon gas to your a/c unit. Air should be coming out cold from your a/c unit once the compressor starts running. Always check if the compressor runs when you start the unit.
Posted on Sep 09, 2011
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Kids reset temperature and now it won't let me set cool to below 70F
May 04, 2009 | Heating & Cooling
Ultrastat Thermostat
70 to 72 degrees maximum surely now we are all supposed to be pulling together to save our planet???
I suggest you download the instructions for your type of thermostat. If the thermostat doesn't work per instructions it is obviously faulty.
You could contact Honeywell for advice over such an important matter.
Nov 17, 2017 | Honeywell Electronic Programmable...
Heating & Cooling Logo
718 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
