Question about Electrolux AWT1012 Top Load Washer
The wash and drain cycles work OK but the gearbox seizes up when the spin cycye starts. New belt installed and tension OK - I can turnthe gerbox dribe pulley by habd in a clockwise direction but not anitclockwise.
    Sergeant:
    Champion:
  • 202 Answers
You have a bad gearbox (trany)
sorry for the bad news
Posted on Mar 22, 2011
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Washer does nor drain
hELLO THERE:
let me explain this as best i can so please read the entire post ok?
Sometimes the most obvious answers are the first ones overlooked. If the tub isn't draining, first check the drain system. Check the drain hose to make sure it isn't kinked. Also check any lint filter that may be installed. On some Whirlpool/Kenmore models, there is also a side-check valve at the tub outlet that can get clogged.
There aren't too many things that can go wrong with a pump. The pump bearings can seize, stopping it from turning. The pump can be jammed by socks or other small items. The impeller blades can break off due to junk entering the pump; if this happens, the pump may seize up, or it may just stop pumping. The usual solution is to replace the pump.
But the symptoms of a pump failure are something else altogether. If the pump locks up, and the motor is still trying to turn it, something's gotta give. If the pump is belt-driven (as it is in many washers) the pulley driving the pump may shear off, or the belt may break. The belt may ride over the locked pulley, or the motor pulley will continue turning under the belt; this will burn the belt and possibly break it. There may even be enough tension on the belt to stop the motor from turning.
The symptoms can be confusing. For example, a common complaint about a Whirlpool belt-drive washer is that it isn't spinning, accompanied by a strong burning smell. The problem is almost always a pump that's locked up. The washer doesn't enter the spin cycle because the spin is interlocked with the drain cycle. This means that the basket won't start spinning until the water is partially drained. The burning smell comes from the rubber belt, which is riding over the motor pulley or locked pump pulley.
NOTE: If you EVER find a broken belt, check for a locked pump, transmission or other pulley before replacing the belt.
If you suspect that something is jamming the pump, drain the tub and pull the hoses off the pump. Look into the hoses and the pump and pull out whatever is jamming it. If you can't see anything jamming the pump, feel around the inside of the pump inlets and outlets with a pair of needlenose pliers. If all else fails, and you still can't find the jam, pull the pump out of the machine and check it.
Nov 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
The clothes are still wetafter rinse/spin. After 2 or 3 more spins they are ok.
check the drain hose for kinks or too much of a rise If the water does not completly drain before the cycle starts it will not spin fast enough to spin out the clothes. also check the belt condition. The belt could be slipping.
May 15, 2009 | Kenmore Washing Machines
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Belt stops running and clicky noises
If this is top loader the gearbox is faulty. Regards Advisor
Aug 23, 2007 | Maytag Performa PAV2200
Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Jul 15, 2007 | Kenmore 24032\24036 Top Load Washer
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Electrolux AWT1012 Top Load Washer Logo
71 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
