Question about Proview PL926WBi 19" LCD Monitor
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
  • 30 Answers
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Posted on Mar 24, 2011
My ProView 19" flat panel lcd monitor goes black 30 seconds after boot. If I turn it off and on it comes on and then goes off after 30 to 50 seconds? Can I fix this?
I askedd this last time but you did not answer. Is the monitor located in a well vented area? Sounds like the monitor has been in a area of poor circulation and has reached a point where it overheats very easily. Try putting a small fan behind it to see if it causes it to stay on longer.
Jan 01, 2010 | Proview PL926WBi 19" LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Screen goes black
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Dec 27, 2008 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Aug 16, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
71 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
