Question about Dishwashers
Error code e4 on kenwood kdw243a any ideas????
  • Anonymous Sep 20, 2008
    i have exactly the same problem. i got a new kenwood 2 days ago :(
  • Anonymous Sep 21, 2008
    I have same problem. kenwood isn't very good and currys even worse.
Error code E4......I have the definitive answer.
All the recommendations to tilt the machine are totally wrong!!!!! It may work in the short term but is a bodge-fix and covers up the "real" problem - you have a water leak- its as plain as that.
There is nothing wrong with the Kenwood and it has a 'Flood Sensor' that is filling with your leaked water.
I too was suckered into this quick fix but it didnt work for me; then I spoke to a neighbour who is also a dishwaher repair man.
We removed the machine , removed both side-panels (yes its easy for a DIY), dried out the water from the bottom pan (the sensor sits in a small recess right in the middle of the bottom pan). The machine was switched on and we checked for a leak; now there are many pipes and you need to observe just where the leak is. In my case the water was pouring from a broken pipe, but worse still it was leaking right onto the mains electricity !!!!!!!
So DONT mess with bodge fixes - they may kill you!!!
Posted on Feb 20, 2009
3 Suggested Answers
SOURCE: kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Posted on Sep 29, 2008
SOURCE: Kenwood KDW243A Built-in DishwasherProduct code:
did you find out what was causing this because mine is doing the same
Posted on Nov 11, 2008
How do I fix my dishwasher it is Glem and is showing E4
I found this. All the errors are generic to all models
Hi I'm a kenwood engineer
E4 means that the flood sensor located in the sump of the machine has got wet!
It only should get wet if the machine is leaking somewhere.
The sensor is designed to switch off the machine if triggered... To save flooding your kitchen!
Very good idea really - as most machines don't have this feature and flood the floor until the cycle is finished.
Yes you need to tilt the machine back to drain the water from the sump first.... Then look for your leak. The leak cud be on any hose or water pump... Or the seal under the filter chamber. Once leak fixed and water drained/dry
E4 should clear. Make sure machine is empty and unplugged before messing! :)
and can also be drain error
http://www.justanswer.com/appliance/1qmh8-belling-dishwasher-showing-error-code-e4.html
There is also a video on E4 errors.
http://www.bing.com/videos/search?q=dishwasher+showing+E4+error&FORM=HDRSC3
Jul 05, 2016 | Dishwashers
What does E4 message mean
It means your leak detector has detected a leak.
Dec 07, 2014 | Kenwood KDW243A Builtin Dishwasher
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
Kenwood kdw243a
Sep 28, 2008 | Dishwashers
Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | EuroTech Dishwashers
KDW243A fault code E4
Greetings dtcldean,
This error message means too much water in your machine.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 10, 2008 | Dishwashers
Dishwashers Logo
1,152 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
