Question about Milwaukee Tool 4253 1 Drill 1/2 Mag Motor 6.2A
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
  • Milwaukee Tool Master
  • 885 Answers
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Posted on Mar 22, 2011
Testimonial: "VERY HELPFUL, I GOT THE JOB DONE WITHOUT A PROBLEM."
Looking for a Milwaukee 48-66-1381 chuck kit with a 38-50-5075 spindle.
sure the age of the tool may have parts discontinued or superseded
this is a Milwaukee chuck kit you can buy
and a spindle on sale
try this Milwaukee parts supplier for a part or dimensions of the spindle/chuck you need
Milwaukee 1670 1 SER 472D Single Speed Hole Hawg Drill Parts 26309591-1jfwbypa2loxnuc0fythdbff-4-0.jpg
Oct 13, 2016 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How can I remove worn spindle for replacement?
Yes much dirt inside its not work for
office workers who find this inferior work or afraid of making dirty hands but to do the job when you will do the job best is to must have a solvent cleaning machine to do this job or a great tub with solvent or benzine at least. and a brush .
Milwaukee 6537 75 SER 986A 75th Anniversary Super Sawzall Parts
Its Look likes you have already unmount pos 35 from pos 34 gear case
now first remove pos 55 bearing cap front unter gear case white or black cap on the drawing remove that first then you set(fixate) the small protruding part of the drive gear pos 45 in a bench vice. and then you can remove the pos 5 spinlock hex nut and then the wobble gear comes free. then the rest is to see that all parts have its positions beware of that .
There is the parts list for position neccesary zoom in if you want to see something in the drawing . IMPORTANT if you will now or in future replace the armature then replace also the great gear pos 45 and carbon brushes. if only spindle pos 51 then also replace pos 65 tube chassis. and pos 53 , 60, 61 ,66 , if you will choice the grease a good multi purpose grease and there should be quite a lot of fat inside the machine , replace also little o-rings which have not yet been mentioned concerning lubrication felt and o-rings.
Feb 27, 2016 | Milwaukee Hand Trucks Milwaukee...
Chuck will only turn side to side after repair of gears box after
I need more information to answer your problem.
The chuck normally has movement turning because of the clutch gear.
It is possible if you had a gear strip or spindle break that there are pieces of metal in the grease that have jammed your new gears. I would recommend tearing down completely, remove all the grease, thoroughly clean gearcase, regrease & reassemble.
Nov 13, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Aug 16, 2012 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
I want to know the steps needed to replace a 1/2" keyed chuck.on a Milwaukee 0234-6 Magnum Drill
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
Jul 31, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
The motor runs (Milwaukee 1670 1 Drill) but the chuck does not rotate. This is true with both low and high gear. I suspect the gears are stripped but never had one apart before. I removed the top cover...
Hi, chances are the spindle driving the check is snapped. This is quite common. At the same time you might (probably) have some broken teeth on one of the intermediate gears and the narrow gear closest to the motor. I have just dissasembled three Hole hwags for a plumber friend of mine and they all have the same damage issues. The cover should come off fairly easily. Give it a couple of taps with a hammer to loosen it. The cost of replacement parts if the issues are the same is at least $100. Some of the spindles are more (the threaded ones) and will bring the cost closer to $170. remove all the grease as broken teeth will be hidden in there. The only thing I have not been able to find is proper grease to put back into the tool. Hope this helps.
Aug 25, 2010 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How do you remove chuck?
There is usually a bolt inside the center of the chuck in addition to it screwing on the spindle. The bolt may be an Allen or Torx.
Jan 12, 2010 | Milwaukee Tool Milwaukee 1680 21 1/2"...
Milwaukee Polisher model 5460. Gear Case Replacement
you need to remove the pad first and then you will find 2 torx screws about a 25, remove them and the plate next if you have a dead blow hammer tap on the side of the gearcase where the screws were and the spindle assembly and bearings will jump out of the housing, then remove the 4 screws holding the gearcase to the motor housing and it will come apart. To reinsert the spindle assembly gently tap back into place with the hammer to reset the gears. Let me know if you need more assistance.
Nov 25, 2009 | Milwaukee Tool Milwaukee 5460 - 6 7/9"...
Milwaukee cordless drill 14.4 gears
usually you would remove the chuck first under my name in the profile section is the tip for chuck removal, it is a standard thread probably 1/2-13. As far as the gears go try the site Milwaukeetool.com and type in your model number for a parts explosion. Let me know if I can help further
Oct 29, 2009 | Milwaukee Tool Drills
Milwaukee Tool 4253 1 Drill 1/2 Mag Motor 6.2A Logo
322 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
andrew-loeb
Level 1 Expert
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
