Question about iLO 2600 Television
Ilo-26hd can't hook up cable because tv wont accept standard coaxial cable. how can i connect cable to this tv?
3 Suggested Answers
SOURCE: ILO 26HD
The ilo tv 26HD turns off by its self after about 20 min. of being on.
Posted on May 23, 2009
  • 4090 Answers
SOURCE: ilo-26HD televison problems
most of the new TV's use a SCAT plug to allow connection of a PC or laptop. I doubt that this TV has that sophistication. The ISB will not do it and neither will S VIDEO.
As for the cable you could try a male to male plug to mnake a coaxial connection. These TV's were made to a price for walmart and you got what you paid for which was a cheap TV. There was no warranty offered by Walmart for these either
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
I have a ilo tv model 26hd it's stuck in cable mode
Go into the menu with the original remote and in the setup should be a selection for cable or air/antenna------you likely need the original remote to do this.
Oct 29, 2012 | iLO Televison & Video
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
Ilo-26HD televison problems
Nov 20, 2009 | iLO 2600 Television
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Feb 22, 2009 | iLO 2600 Television
Ilo 26HD
Well you may have to rescan for cable if you have cable if not then your tv tuner probley went out and the tv does not notice a signal. hope this helps
Sep 24, 2008 | Televison & Video
ILO 26HD
Jun 10, 2008 | iLO V27DMBX Television
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
Televison & Video Logo
118 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
