Question about Delta & Single Handle Shower Faucet
I have black particles coming from my bathroom tub spigot, what could it be?
  • 4,354 Answers
Sounds like washer pieces. Your faucet has rubber parts and they can eventually fail, Look also at the shut off valves, as they break apart (the washers) eventually.
Posted on Mar 22, 2011
What brand plumbing in shower
most taps for bathrooms have replaceable spigots and handles of various design that suit the shaft. I would be talking with a plumber as to what you have and as to why any spigot assy will not fit. Even if you have ceramic inserts they still fit the tap proper.
Jun 17, 2013 | Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
How to fix the particle board side of a bathroom
These particle board vanities are very cheap and as always you get what you pay for, the only real solution is to replace it you won't be able to get it in the shape it was.
Jun 28, 2010 | Home
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
We began replaceing our galvanized pipes. Since
The problem is that when you disturb the galv. pipes, the gunk inside breaks loose, and travels to the faucets, gets stuck, and limits the volume of water that comes out.
If possible open the lines at the service valves, and force water through the spigot to fluch out the faucet. The service value could also be partially clogged, keep that in mind
Aug 05, 2009 | Plumbing
Black gunk in bathroom faucet screen
Okay, you have black gunk in the screens of your water faucets.....This is usually found in homes with old metal galvanized water lines that have a well or Hard Water. To permenantly get rid of this problem you should have a water softener installed and replace old water lines. If you already have a water softener then you should replace all of your old metal water lines with Copper or Plastic (Plastic being the cheaper way to go). After many years of use, the inside of the galvanized metal water pipes get a Gunky Skummy Build up on the inside of the pipes from minerals and particals in the water, usually in older homes and farm houses. You will see this Gunk if you take a section of water line apart and look in it. There is no really Cheap fix for this, But if you and a Partner a fairly handy, you can do it yourself with CPVC Plastic pipe and Glue. By doing it yourself you will save alot of money on the cost of labor. If you can afford it, Hire it out to your local handyman or plumber. After replacing the water lines you should no longer get the Gunk build up and may even notice a bit more water pressure....I hope this helps in assisting you to the solution......Joe
Jan 14, 2009 | American Standard Colony 3275.505 099...
Ge wbse2090a2 won't drain
Check the drain spigot that the drain hose attaches to under the sink/tub. There may be a blockage in the spigot.
Oct 25, 2007 | GE Energy Star WCVH6260F Front Load Washer
Delta & Single Handle Shower Faucet  Logo
81 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
