Question about Prestige Remote Start
I have a prestage remote starter, my car is 2008 ford explorer, after a few days my car will not start, it makes a clicking sound
  • Audiovox Master
  • 625 Answers
The vehicles makes a clicking sound when using the remote starter? Does the vehicle make the same sound when attempting to start with key? If so, this sounds like an issue with the vehicle not having enough power to start the car or, there is an issue with the vehicles starter.
Posted on Mar 24, 2011
2004 Ford Explorer won't start if I let it sit for a a few days. I turn the key and it just clicks but will start with a boost. I have had the battery and starter checked and the mechanic couldn&#
Why didn't the mechanic continue on & resolve the issue?
You don't have the experience to do so, as your here
No one can tell you what is wrong without the vehicle to test,
common sense
Feb 07, 2013 | 2004 Ford Explorer
1996 Ford explorer 4WD wont start
Either your starter or battery
Jul 16, 2012 | 1996 Ford Explorer
I have a 2008 Ford Explorer. If I stop to restart after a short time say about two minutes, the vehicle would not start. The engine would not click but everything else would come on. After trying for...
sounds like a problem with the starter, i had the same thing happen to me when i took the starter to get repaired the guys to me i was losing the voltage in the starter they installed a relay on the outside of it charged me twenty dollars. that was a year ago haven't any more problems. hopefully yours will be that easy.
Apr 06, 2011 | 2008 Ford Explorer
My 2004 ford explorer wont start, theft light on dash blinks fast when key is turned on to start. all dash lights come on, just nothing to the starter. hear a clicking under dash fuse box thats it. what...
got a 2004 ford explorer it wont start but it turns over put fuel pump starter evap canister and purge valve it was broke,and a battery fuel filter,tac system and it still wont crank
Mar 27, 2011 | Ford Explorer Cars & Trucks
2000 explorer will not start makes clicking sound replaced battery,plugs,wires,starter
Fords usually have a starter solenoid separate from the starter. If the contacts are bad in the solenoid it will make the clicking sound. Replace the solenoid and it will start.
Mar 05, 2011 | 2000 Ford Explorer
2003 ford explorer will click and not start. a few days later it started.we cannot trust it tto start. a mechanic says it could be a loose wire to the starter or we need a new starter. please advise.
First, try a new battery or charge a known good battery up and install. Make sure the connections at the battery and the starter are shiny and clean when removed. Do an amperage draw test to see how many amps it draws when trying to start (click).
If the amperage draw is 80 to 120 Amps and it doesn't turn over vigorously, the starter is bad, but the connection is good.
If the amperage draw is only 1 or 2 amps and it doesn't turn over, then the soenoid on the starter is bad, but you would change the starter and solenoid together as a unit to repair.
Good luck on this repair.
Jan 29, 2011 | 2003 Ford Explorer
When I shut off the motor sometimes it wont start. I just bought a new battery 2 months ago. When I turn the ignition the starter doesnt even make a clicking sound. I can jump it or let it sit a couple of...
It might be your anti-theft alarm system. When the car doesn't start, is there a ticking sound inside the car? If so, hit the unlock button a few times on your keyless entry remote, until the ticking stops, then try to start the car. Hopefully this helps.
Mar 27, 2010 | 1998 Ford Explorer
92' Ford Explorer Starter?
P.S.
Check you positive side cable for corrosion and you might need to replace the cable because it runs from the battery direct to the starter and to the starter relay that is mounted on the right front fender under the hood. You have 2 (two) starter relays on your Explorer.
Aug 18, 2008 | 1992 Ford Explorer
Won't start
The clicking sound could be the sound of the silenoid trying to activate a bad starter. See the bendix moves in and out pushing the gear into the flywheel. The starter itself turns the flywheel. So they are a working combo. You sound like you may need a new starter. Here is a tip. Buy original equiptment or get the same one rebuilt buy a shop. Many alternator and starter shops (even tractor repair shop) can handle this type of work in less than a day.
Jul 26, 2008 | 2003 Ford Explorer
Prestige Remote Start Logo
514 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
