Question about Acer Aspire Notebook
My acer screen is just blank i think it took a knock is there a quick fix
  • 1,591 Answers
You may have cracked or broken the FL tube (backlight) or the inverter board has failed.
If the tube is broken, it needs to be replaced (or you can replace the whole LCD if you find one cheap).
If it's the inverter board, look for a microfuse on the inverter board (the one connected to the FL tube). These fuses will sometimes go for no reason. Check it for continuity with an ohm meter.
If the fuse is good, you may need to get the inverter board replaced.
To find out if you damaged the fl tube, you have to open up the LCD panel.
This is not a job for the faint of heart, and you have to be really careful not to damage anything.
They usually shatter when they break too, so be careful there.
You may just want to tap the backlight area to see if you hear rattling glass.
Check for loose or dislodged cables while you're in there.
Posted on Mar 22, 2011
Acer Aspire One has a blank screen, but is logging on and able to function. Can click and hear sounds when I do and when it starts up, as if it were running normally, but the screen is blank so I can't...
Connect an external monitor and use the computer to check the screen settings. If changing the settings doesn't fix the problem, the screen or the lamp driver needs to be replaced. I have seen many Aspire One with screen problems, appears to be quite common.
Good luck
Nov 23, 2010 | Acer Aspire One PC Notebook
Aspire one notebook's screen was blank
Seems that it lost BIOS. There is a way to recover it - go to macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Sep 24, 2009 | Acer Aspire One PC Notebook
Acer one netbook screen blank on power up due to graphic driver
Does your laptop get past the startup screen? If not, then I doubt it's the graphics card driver that needs to be installed...I worked on an Acer One netbook a while ago and I found out that the wireless card was the problem. I took it out and the laptop worked fine ever since. I think I've read somewhere that Acer One's have a problem with their wireless cards. Though, it is a pain taking out the wireless card since you have to completely disassemble your laptop.
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Blank screen but powers on
hi had same problem with my acer laptop,took screen off and the connector had come out of the socket,once this had been pushed back in all worked well . good luck.Gary.
Apr 26, 2009 | Acer AOA150-1690 Aspire Notebook
SCREEN WON'T WORK
so dude at work took it apart and totally fixed it for free---
Mar 30, 2009 | Acer Extensa 5620 Notebook PC
Blank Screen Acer Aspire 5920
im afraid that your screen is broken, but try to move the screen foward and backward littlebit, my friend also have the same problems and only by contact local support using his warranty the problems fix, you may open your laptop to see if something wrong with the wire but i think its not practically good.
Jan 28, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 4530 webcam isnt seeing me
i think your gonna need to uninstall came and reinstall or do a system restore back to factory default
Jan 16, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 PC Notebook
hi!!!
may be the power option
try to check it!!!
ok go to start
then setting
go to the control panel
click on the power option!!!
Oct 31, 2008 | Acer Aspire 5100 Notebook
Blank Screen
It may be a resolution setting issue...the game may be outputting in a resolution that your tv doesnt support. Try going to your video settings and knocking the resolution back to 720p for your HDMI output....in settings under video, select your ouptut, and uncheck the boxes next to the types above 720p. Also make sure you have latest software update for ps3.
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Acer Aspire Notebook Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
