Question about Flotec 1/6 Hp 1260 Gph Utility Submersible Pump
Can i use this pump in my salt water fish tank
  • 56 Answers
I would not recommend a utility type pump for any aquarium. Most of these pumps eventually seep oil into the water and that will quickly end any aquaculture project you have going. Also the aluminum does not fare well with saltwater and will poison any invertebrates sensitive to metals in the water.
Posted on Mar 22, 2011
  • 368 Answers
Glad to HELP YOU!
I am an aquarist for MANY YEARS. I do have few tanks at home, one with fresh water and other three with saltwater (reef and fish only).
I'd suggest you DO NOT USE such pump into your saltwater tank.
Stick instead with the classic ones: CORALIFE, MARINELAND, ATLAS and so on.
This Flotec 1/6 Hp 1260 is used mostly for PONDS and DECORATIVE FOUNTAINS. In saltwater some of its plastic parts will release TOXIC SUBSTANCES that will KILL your livestock!!!
My best wishes!
Testimonial: "Thanks "
How to treat my Betta fish ick
  1. The first thing you should do is remove your betta from its current tank. You will want to set up a separate temporary container to house your betta while you clean his regular tank. Be sure to use clean water that has been treated with water conditioner. If a separate tank is not available, you will want to do a full water change on the tank along with a thorough cleaning. Again, be sure to add the appropriate amount of water conditioner before adding your betta back to the tank.
  2. Ick thrives in cold water, so after you have a clean tank setup, you will want to install a tank heater to warm the temperature gradually to 82 degrees. Be sure to use the proper size heater for your tank size. Also, make sure the heater has a cut off switch or something to keep the temperature from going over 82 degrees. You don't want to cook your fish!
  3. Now you are ready to treat the ick. You will need an antiparasitic medication. Try Kordon Rid Ich Plus you can pick it up at most pet stores. If they do not carry it, ask for another antiparasitic appropriate for betta fish. Use according to package directions.
  4. Continue treatment according to directions.
How to keep ick away:
  • Continue using heater to keep water at 82 degrees
  • Do frequent water changes with water conditioner added to clean water
  • Use aquarium salt: it is inexpensive and easy to use. Purchase from pet store and follow package directions for use.
    Good luck! I hope your fish gets better!
Mar 01, 2015 | Marina Aquarium Cubus Desk Fish Tank Betta...
Tip
Using a pH meter to care for your fish
pH values are the acidity of a body of water. Neutral water has a value of 7.0 meaning that it has equal amounts of hydrogen ions and hydroxide ions. When more hydrogen ions are added the water then the number goes down and the water becomes more acidic, or if the amount of hydroxide ions goes up then the water becomes more alkaline.
pH levels in your fish tank can prove to be fatal if they aren't monitored properly. While there is no secret formula for the perfect pH level for all fish it is best to keep all the fish from the same bodies of water together. Salt water fish shouldn't be put in a tank with freshwater fish because they need different pH levels.
Throughout the day the pH level of your fish tank will change although these slight changes shouldn't be too harmful on your fish sudden changes will prove to be fatal. When you are moving fish from one tank to another you want to make sure that the two waters have the same pH levels. When you want to buy a new fish check the pH level of your fish tank and then the pH level of the water at the pet shop to make sure that the levels are not too different.
You should be checking the pH levels of your fish tank at least once a month, but more often is always better. When you take the pH level you should write it down in a log book. You should try to take the pH level at the same time every time you take a reading because at different times of the day the levels would be different. Try to keep yourself from going crazy, if the pH level is a few decimals off of perfect your fish will be okay. If the level is fairly regular you shouldn't have to do anything unless your fish show signs of distress.
on Feb 02, 2014 | Measuring Tools & Sensors
Why is water sitting in the tank and how do we get it to drain so we can add salt?
the salt water is what removes the calcium and lime from the other tank containing the compound zeolite that does the actual softning of the water the salt tank should have water in it drain some out pour in salt
Oct 10, 2014 | Northstar North Star Water Softener , Flow...
Culligan water softener manual
You are likely using a rock salt and what you are seeing is a build up of dirt and fine sand because rock salt isn't clean... it's got rocks in it. Clean your tank out and rinse it thoroughly with a hose. Be sure to clean out your 3" tube (brine well) and under the salt platform if you have one. Start with a clean salt like System Saver II or Crystal Plus. Never fill your salt tank over half full. Always let your salt be used down to the water level. IF the salt at the water level is soft and pasty don't add more; tip the salt tank until the salt is raised along one side or corner to above the water level when you stand the tank up carefully. This will allow all the water in the tank to become brine (saturated solution).
IF you are using potassium instead of salt, the brown is a natural component. Don't worry about it although it never hurts to clean your brine tank yearly.
Aug 04, 2014 | Water Dispensing & Filtration
Cloudy water that stinks
1st priory is to save the fish !! move them to a new container consisting of half old water and half new water (declorinated) along with a small air bubbler !! this should help your fish to recover (don't use soap to clean out container it is toxic to fish) moist table salt is best to use for a cleaning agent and rinse well b4 putting fish inside
then ck to see if your aquarium is pumping water thru the filter and falling back into tank ( replace all the water in the tank 1st with two rinses ) make needed repairs to pump and or filter assembly (New filter cartridge) new pump impellers and cartridges are available for purchase for your aquarium from vendors that sell aquariums and allways ck the outlet the pump is plugging in b4 blaming a pump fail with a known good table light set to "On" they do go off once and an a while
verify that water chemistry is ok b4 retuning fish to tank and observe fish for strange behavior for next several hours ( upside down swimming, laying sideways )
Jan 02, 2014 | Marineland Filtration Eclipse Seamless...
What is the difference between fish and seafood?
Fish can come from fresh or salt water where seafood only comes from salt water (hence "Sea"). Also, seafood generally refers to shellfish or things like squid and octopus.
Jan 10, 2013 | Cooking
Aquarium water is cloudy
This can happen and will generally clear with time, if you are concerned do a water change. I find that this treatment is more hassle than its worth, if you have a suitable filter seachem denitrate is a good alternative, or he aquarium pure balls.
Sep 21, 2012 | Tetra 16176 3.38 Oz Easy Balance Water...
My fish tank air pump broke and I think my fish aren't getting enought oxygen because of it. Should I buy a new one or can it be fixed?
Technically, it can befixed but if it happens once, it will likely happen again. You should buy a new one as they aregenerally pretty cheap. In the meantime,fill a large bowl with water and place the fish there. This will allow them to get some fresh oxygen. While the fish are in the temporary container,get rid of all of the water in the tank. Then, refill again with new, oxygenated water. I wouldn't leave them in this environment formore than a day before you purchase a new air pump.
May 13, 2012 | Fish
Flotec 1/6 Hp 1260 Gph Utility Submersible Pump Logo
204 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
