Question about HP Deskpro EP 6400X Model 10000 CDS PC Desktop
When i try to turn the monitor off the power button lockout comes up i need to know how to fis it so i can turn the monitor off
  • 187 Answers
You can just unplug the power cable to turn it off then try using a pen or a stick to unlock the power button.
Thanks & Regards,
(-_-)
Posted on Mar 22, 2011
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Apr 09, 2015 | Microsoft Windows 7 Home Premium 64BIT...
    Osd main controler lockd
    Hi there.
    OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
    This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
    The HP Fixes
    FIX 1
    Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
    FIX 2
    Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
    FIX 3
    FIX 4
    The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
    The AOC Fixes
    FIX 1
    Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
    Currently these are the most commeon fixes.
    ~ Slasher_X
    Sep 28, 2011 | Philips 190B6CB/27 19" LCD
    What does osd lockout mean and how do i get the box off my computer
    Lockouts occur when the software driving the OSD encounters a problem or conflict--akin to your PC's operating system freezing.
    Follow this link for more info: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
    Basically you have Four options to solve an OSD lockout.
    Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
    Fix Two:
    Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
    Fix Three:
    Fix Four:
    The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
    Good luck and thanks for using FixYa.
    Feb 22, 2011 | HP w1907 LCD Monitor
    Starting the PC have got error on HP 1730 Monitor error message, OSD Lock out. Can you please tell me how to solve this issue?
    How to Unlock an "OSD Lockout" Problem
    smilie-tag.png monitor, osd lockout folder-category.pngPosted in Fixes ' Comments (32)
    osdlockout.jpg This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
    Fix Two: Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
    Fix Three: Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
    Fix Four: The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
    If you know of any other fixes feel free to contact me. Good luck!
    Having other problems with your computer? Simply scan your computer for free to identify problem areas.
    Techbelkin please rate me
    Nov 02, 2010 | HP 1730 LCD Monitor
    When i press the power button on myn monitor i get a popup mon my screen "power button lockout" how do i solve this? i hve a window 7 hp computer. the power buton on the monitor was squeeze...
    try..... it worked for me. Power Button Lockout is displayed.The monitor's Power Button Lockout function is enabled.
    Press and hold the power button for 10 seconds to unlock
    the power button function.
    Thanks for using Fixya
    Proton
    Sep 11, 2010 | HP dx2300 Monitor Personal computer Intel...
    How to unlock OSD lockout in HP L1940T Monitor
    How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
    Jan 20, 2010 | HP L1940T 19" LCD Monitor
    HP 2009m monitor. OSD lockout keeps appearing on
    OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
    try holding menu button also if it doesnt workout
    Nov 30, 2009 | HP 2009M Monitor
    OSD Lockout bananas
    Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
    May 23, 2009 | HP w1907 LCD Monitor
    OSD LOCKOUT
    1. Replaced the Micro switchs.
    2. press the menu switch 15 to 20 secunds.
    Nov 02, 2008 | Computers & Internet
    HP Deskpro EP 6400X Model 10000 CDS  PC Desktop Logo
    57 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
