Question about Car Audio & Video
My jensen uv10 is stuck in camara mode. How do I get it to reset? I have hit the reset button on front panel and also unpugged harness on back of radio
messstat
  • 365 Answers
SOURCE: I need to buy the wiring arness for Jensen Car
Not available, sorry!
Posted on Jan 02, 2010
BLAZZ81
  • 281 Answers
SOURCE: jensen UV10 screen wont work
this is a big problem with this type of decks,, if its only 2 weeks old take it back to the store!
Posted on Mar 12, 2010
  • 173 Answers
SOURCE: i have a jensen uv10 and cant get the radio on the
connect it to the aux 1 or aux 2 inputs. buy the adapter at walmart in automotive section were the dashkits rca jacks are it should be $5
Posted on Mar 21, 2010
supertech6
  • 513 Answers
SOURCE: wiring harness
You can try these people.
I have not dealt with them. You can contact Jensen directly. Be aware these harnesses are not cheap.
Posted on Apr 16, 2010
  • 6 Answers
SOURCE: Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Posted on Aug 13, 2010
Does the Jensen UV 10 stereo have internal fuses that can be replaced
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jan 15, 2017 | Jensen Car Audio & Video
Full Color Back Up Camera Install. I need to know what I specifically need in order to do this- exactly what I need to buy.
Google Search jensen uv10 camera and you will see a good list of references, videos, and cameras available.
Mar 06, 2015 | Jensen Car Audio & Video
How do you switch the am/fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen with no remote?
touch source button in the upper left corner until the tuner options are on, or until you see the stations,m then hit seek or tune to get the station you wish to play.
Nov 21, 2014 | Jensen Car Audio & Video
How do you switch the am and fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen
touch the source button in the upper left hand corner until you see radio, then hit tune or seek to get the stations you wish.
Nov 21, 2014 | Car Audio & Video
Jensen uv10 wiring plug on each row what goes where
I would just look to see where there is a picture of the wire harness on line and check the wire colors with the manual.
Sep 23, 2014 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
No audio with uv10
I have Jensen uv10. I hooked it up and this no sound in a 94 f159 4x4
Mar 20, 2011 | Jensen Car Audio & Video
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
I have a jensen uv10 and how do i connect my bluetooth when the picture under the soure is not lite and wont let me click on it
You actually have to purchase the bluetooth module seperate, its just a box that clips to you're visor and has a microphone and a connect button on it. It has one cable which is ran to the back of your stereo. The one made for the uv10 is called the btm10. However I have found that the btm15 works much better and has 2 microphones in it (one for calling and one for voice searching). You can find these on amazon and also jensen.com the price range runs from $40.00-$80.00......... Hope this helps you out...
Dec 16, 2010 | Jensen VM9510 Car DVD Player
UV10 Works 100%!!!!
Jan 28, 2010 | Jensen Car Audio & Video
Need the parking bypass code for jensen vm9510
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
6. I am not responsible for whatever you do with this code!!!
Mar 03, 2009 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
