Question about Sharp Audio Players & Recorders
I have a Sharp VZ 2500. The drive belt lies in pieces at the bottom of the player, so I can assume it needs replacing. I've bought the belt, but have no idea where it goes. Can you help?
  • Alex vz2500 Nov 09, 2008
    Oh my word! It's working! Damn, this thing's loud. Thanks so much for the instructions, they were bang on.
    It skips a fair bit, and feeling the needles, I'm guessing they need replacing. Any pointers, again, would be much appreciated.
You have to remove the front cover first. then detach the two wire connectors attached to the turntable circutry. Also detach the pushbutton pannel. remove the two screws that fix the top plastic cover inside the turtable housing. then the two big screws that fix the turntable to the main body will be visible. remove them and you can detach the turtable unit out. then remove the circuit board behind the turntable. you can then put the belt between the big disc and the motor pulley on the corner. Good luck
Posted on Oct 12, 2008
Need a belt for K6725 breadmaker bjc
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Aug 04, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Holden commodore vz acclaim my06 remove front headrests
push in the button on the left headrest post and use a small piece of coathanger wire and do the same to the other headrest post. There is a small hole in the side of the plastic. Now pull up on headrest whilst doing this and it should come out.
Jul 08, 2009 | Baby Gear
I need a drive belt for my regal breadmaker machine, model k6725
Patti Wilson
September 2009
Jul 02, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Need a new belt for the Regal K6725 bread maker
Patti Wilson
September 2009
May 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Pro K6725 drive belt shredded.
Patti Wilson
September 2009
May 28, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
BELT BROKE NEED REPLACEMENT IS THERE A DISTRIBUTER THAT I CAN GET THE PART FROM
image_icon_name.gifPatti Wilson
image_icon_date.gifSeptember 2009
May 05, 2009 | Regal Ware K6745S Kitchen Pro Bread Maker
Regal-Oster belt conversion possible?
Patti Wilson
Feb 16, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Turn table not going round on a Sharp VZ-1900E?
Please help as I have this problem too and can't see how to get into it to change the belt
Apr 15, 2008 | Sharp Audio Players & Recorders
NEED A NEW DRIVE BELT (RUBBER BAND)
I had this problem. The drive belt that lifts the disc reader was too worn out to lift up to the disc. I replaced it by taking a regular sized baloon and cutting off the rolled up piece on the bottom. Worked  great in place of a belt.
Jan 29, 2008 | RCA DRC350N DVD Player
413 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
