Question about Frigidaire Refrigerators
My freezer do not work, the light is on in the bottom
  • 6,993 Answers
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
I hope the above helps.
Good luck........
Posted on Mar 22, 2011
How do I fix the freezer light in my Whirlpool side-by-side/freezer on bottom fridge?
first make sure the light bulb works for sure. then most likely it is the door switch. easy to replace. pull out, disconnect and replace. while you are at it, touch the two wires together and make sure the light goes on so you know it is the switch.
Aug 09, 2015 | Whirlpool Refrigerators
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
The Sub Zero bottom dram freezer has stopped working
HI,
What does you freezer do? Does the lights work and fan work? The fan works with the cold control, if the light switch fails the unit will defrost in about 3 - 4 hours, will remain cold though, just not frozen. I need more information to direct you correctly.
I am here to help
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Bottom freezer suddenly had condensation and light wasn't working
That could be the fan in the freezer with ice build up in the area of the evaporator coils which would indicate a problem with the auto defrost system the evaporator coils are behind the back panel of the freezer .
Aug 30, 2009 | Amana ABB1927DE Bottom Freezer...
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
