Question about Broan-NuTone Allure II QS230SS Kitchen Hood
The ventahood comes on by itself and difficult to tuen off. my husband had to disconnect
  • 726 Answers
Those are designed to turn on automatically while cooking. my parents hood does same thing. it comes on when stowe is in use and it turns off when cooking is done. it may be normal operation. check your owners manual.
Posted on Sep 18, 2011
Husband did something to my car so I can not start it.
Hi Debra:
If this was intentional I suggest that you have troubles other than your car.
If it was no intentional then perhaps you could ask him to describe what he did, share that information with us, and hopefully someone will be able to assist.
Jan 12, 2016 | 2005 Pontiac Grand Am
Ventahood b200msc
That would depend on what country you are in. If it is not the USA then it is most likely the voltage is 220. The products are listed here: http://ventahood.com/specifications.jsp IT appears that you dont have the right model number.
Apr 07, 2014 | Kitchen Ranges
Ive got a truimph bonneville t100 2008 exhust pipes tuening blue at the head and golden by the silences is this detremental?
It is 100% normal and caused by the exhaust heat. A pointer though; if you do any work to the bike and had touched the exhaust pipes, clean them thoroughly before running because you will end up with fingerprints on the pipes that will be extremely difficult if not impossible to remove. Safe riding.
Jun 24, 2011 | Triumph Bonneville T 100 Motorcycles
Akai pt50dl24 keeps turning off on its own
My 63" AKAI TV tuens itself off by itself anytime, no pattern?
Apr 12, 2010 | Akai PT50DL24 Television
I have numbers and lettters that come up on the top left of my screen. is there anyway to get rid of them?
Most likely the TV is in the service mode. On the front of the TV while it is on press on the POWER and ACTION buttons at the same time and hold them down until the set resets itself and comes up with a service check screen. You can then power the set off then tuen it on again and the serviceman mode will be exited.
Nov 06, 2009 | Panasonic PT-51HX40 51" Rear Projection...
My husband is not mechanically savvy. That being
It isn't too difficult just do one at a time. Disconnect from your battery and then disconnect other end where it attaches to engine. There may be brackets along it's length that will have to be removed that secure it make sure to reinstall these on the new cables. I would suggest though before attaching your actual ends to your battery go ahead and replace bothe cables so you don't accidently arc your positive cable anywhere. It's just a safety precaution. Remove your negative battery connection before starting procedure.
Nov 03, 2009 | 1997 Ford Expedition
1990 Toyota 4Runner fan connection broken?
ita the water pump. quite simple to change
Jun 07, 2009 | 1996 Toyota 4Runner
Frigidaire over the range microwave oven has stopped heating...you set the timer and it acts like it is coming on (light and timer works, but no heating happening). the ventahood and light still...
The high voltage power supply for the magnetron, or the magnetron, or the output drive from the logic uPC board may have failed. The service tech is able to test these areas by taking readings to determine where the fault is.
Jerry G.
Apr 19, 2008 | Microwave Ovens
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
356 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
