Question about Mitsubishi LT-55265 55 in. HDTV LCD TV
I have a Mitsubishi LT-55265 LED TV with wifi capability. It keeps losing the wifi connection when I turn it off. When I try to reconnect, I have to retry several times before it finally connects. The error message says connection couldn't be completed due to network problems or incorrect password. Re-entering the password doesn't help. My wifi signal is full strength and my laptop and printer never have a problem with the wifi connection. When I first got the tv set up a few months ago, I never noticed the problem and the internet connection would always come back after turning it off. Any ideas?
  • 179 Answers
SOURCE: Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Posted on Nov 28, 2007
  • 301 Answers
SOURCE: Mitsubishi WD-62528 blue tint
tv is getting dirty internally
Posted on Mar 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
SOURCE: Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Posted on May 19, 2009
My Lt-55265 LED Mitsubishi blue light is on & the green light constantly flash - HELP
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty or firmware is corrupted.
Jul 13, 2015 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
My hipstreet aurora hs-7dtb6 won't connect to a wifi connection. i have the wifi turned on and n tried connecting it to my home wifi connection but it won't seem to reconnect, it did connect to my wif
If the signal is too weak the connection will be unstable. If you have a lot of wireless routers in your neighborhood it could be affecting your connection. Everything will work fine then the neighbor turns on his equipment and you lose your connection. Try switching the router to a different channel. Try channel 11.
Oct 18, 2014 | Computers & Internet
LT-55154 Will not power on Led blinks four red eight yellow
Make sure all your connections are solid. You may want to try resetting it. See Appendix B: Troubleshooting in the manual downloadable here... http://www.manualslib.com/manual/296300/Mitsubishi-Lt-40164.html#product-LT-55154
Aug 05, 2014 | Mitsubishi LT-55154 55in 1920x1080 16 9...
Mitsubishi 265 input problem
Type in the name for the device your connecting to the input---blue ray,cd,game
Jan 20, 2013 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Split screen and horizontal lines on Mitsubishi LT 55265
Try unplugging,and try with other stuff disconnected to see if they are causing this,if nothing is connected and resetting,unplugging does nothing,then a trip to the repair shop.
Nov 02, 2012 | Televison & Video
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Mitsubishi LT-55265 55 in. HDTV LCD TV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
