Question about Briggs & Stratton Garden
I have a BS 35 Clasic lawn mower.Starts well but cannot get any increase in the RPM. I removed the filter and can see 2 springs Obviously the main butterfly valve is not opening when the throttle lever is moved to the fast position.can some one please advise
    Problem Solver:
  • 8 Answers
The needle and seat has trash in it plus the float is out of adjustment
Posted on Mar 22, 2011
Gcv530 mower starts ok but engine completely cuts out when throttle increases
check for blocked main jet / water in carby
check fro blocked filter at the tap ( if fitted) or problem needle and seat in the carby.
Apr 09, 2015 | Honda Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Talon mower wont rev
may have to bend arm where governor spring goes
Jun 10, 2013 | Talon Rotary Lawn Mower
6.75 horse push mower firing probs
This is obviously fuel starvation, you need to remove the carb and clean the internal jets, you may be able to just remove the float bowl and blow some air up through the main jet.
May 19, 2013 | Garden
Low RPM's
I know this is an old post but I figure maybe my solution will be found by someone else doing a Google search and it can help them. Hopefully, you've gotten yours fixed in the 10+ months since you asked this.
Anyway, if you remove the top plastic shield from the mower (two screws hold it in place, plus a small cover near the air filter that needs to be removed) you will see a small spring that attaches to a tab at the front of the mower. If you bend that tab forward it will put more tension on the spring and increase the engine speed. You'll know if you are looking at the correct spring if you lightly press on the spring and the engine speed increases.
It is a good idea to monitor the adjustment with a tachometer. My owner's manual says the engine has a 3,100 max rpm. You don't want to set it above the specified rpm or you'll probably burn the motor up in a short time. I set mine at 3,060 rpm. It's hard to get it perfect but I figured slightly low is better than too high. Mine had been running at 2,800 rpm.
I bought a small engine tach on eBay for around $9. The wire wraps around the spark plug wire 4-5 times and then you can read the engine speed. It also keeps track of how many hours the engine has been running. I figure that will come in handy for oil change intervals so I permanently mounted it to the mower. It almost looks like it came that way from the factory. :-)
Here's the tach I bought: Hour Meter Tachometer 2 & 4 Stroke Small Engine
Aug 26, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 | Garden
It seems as if my toro personal pace mower is stuck in the choke position, it will not increase the RPM's. Could the be caused by a dirty air filter?
check to see if the idle spring on carburator is connected, if the pop off the engine will only idle a very low speed or choke out. plus it doesnt hurt to clean the air filter
May 05, 2011 | Garden
I have murray self propelled lawn mower. Last
Remove the air breather filter, it might be dirty. Stephen.
Sep 21, 2009 | Garden
MOWER WILL NOT RUN AT FULL POWER .
try empting the feul tank and put fresh feul in with a little dry gas treatment if that dont work try getting some carb cleaner in a spray can start mower and gingerly spay into carb trying not to over flood it keep spraying untill running smooth change CRANKCASE OIL and AIR FILTER.
Apr 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower carburetor
It is a tecumseh , remove screws from intake pipe to block
mark holes for linkage don't stretch springs.
Remove bottom bowl nut it is reg thread so turn counter clock wise . parts needed 631021b bowl gasket and needle and seat,
36786 intake gasket,
632547 2 o rings,
36905 air filter .
Use a can of carb cleaner auto zone spray all holes even the one
on the bowl nut , take out center plastic main nozzle out put on the new o rings put back in , some time the nozzle will brake part 3 640019 .
Remove seat can use comp air or make tool out of paper clip don't
scratch the side when pulling out
Good luck
Feb 02, 2009 | Oregon Scientific Oregon Fusion Blade For...
Garden Logo
139 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
