Question about Dell OptiPlex GX150 PC Desktop
My dell optiplex gx150 wont boot. i am getting primary hard disk drive1 not found. secondry hard disk 0 not found strike F1 key to continue, F2 to run the setup utility
    Problem Solver:
  • 8 Answers
Sounds like the boot sec is missing run restore disks
Posted on Mar 22, 2011
Diskettedrive 1 seek failure primary hard disk drive 1 not found secondary hardisk drive 1 not found cp says strike f1 but cp boot only up to xp logo then re start again and so on again and again
If both of the hard drives are on the same data cable/disk drive controller it is unlikely that both the have failed. Reseat the data cable connectors on the hard drives and at the motherboard.
Reboot you computer and hopefully it will boot up.
Check the BIOS configuration to see if the BIOS detects the hard drives.
If not the disk drive controller on the motherboard may be faulty.
Aug 26, 2011 | Dell OptiPlex GX150 PC Desktop
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Secondary drive 0 not found
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
Pc won't boot
In your system actually the hard disk is not found because of some loose connection; so you just try to remove your hard disk and then start your pc and shutdown it after 1 minute. and then just attach your hard disk properly.
Check all the cable.
Mar 02, 2009 | Dell OptiPlex GX270 PC Desktop
Cannot boot my dell dimension 3000
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Won't boot
Just reformat, see if that helps.
Oct 18, 2007 | Dell Dimension 3000 PC Desktop
Dell OptiPlex GX150 PC Desktop Logo
310 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
