Question about Nikon D5000 Digital Camera
Having difficulty in finding a good tripod to hold Nikon D5000 steady especially on un-even ground and with additional larger lenses
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
A cheap discount-store tripod isn't worth the money. For the best results, you need a good tripod. Unfortunately, it's almost a law of nature that a tripod that's light enough to carry isn't going to be steady enough.
Visit a good camera store (not a department store that happens to sell cameras) and try some out. You want to find a good tripod that balances weight, stability, and cost. Only you can decide where that balance point is for you. Check the web. Here's one essay that may help (and may dishearten you):
http://www.bythom.com/support.htm
Yes, a good tripod will cost money. But a good tripod will still be a good tripod ten or twenty years down the road, long after you've replaced your current camera. I'm on my fourth tripod now, and I wish I'd bought it first and skipped the first three.
Posted on Mar 22, 2011
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Oct 05, 2014 | Nikon D5000 Digital Camera
Is Tamron AF80-210 compatible with Nikon D3000?
This is the tripods and monopods forum, perhaps you would have more luck posting in the camera lenses forum.
Hope this helps
Sep 11, 2014 | Nikon D40 D40X D60 D80 D90 D3000 D5000 &...
Rokinon 500mm for nikon D5100
The filters go on the back of the lens (the end that connects to the camera). If you detach the lens and look inside, you'll see a threaded ring. Simply screw the filter on, similar to how you put filters on the front end of other lenses.
Due to the great magnification ratio of this lens, you absolutely need to have it on a tripod or other stable support. Even the slightest camera shake will be magnified.
The lens also has very little depth of field, so you must focus precisely. Since you're mounted on a tripod, you might want to activate the LiveView feature and zoom in the subject while you focus.
Jul 17, 2012 | Rokinon 500mm / 1000mm F 6.3 Black Lens...
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Rokinon 800mm F/8 Multi-coated Lens for Nikon will this go on a nikon 5000 Thanks for your time
Yes. Of course, the lens isn't an autofocus lens so you'll have to focus manually. Also, the lens does not have the electronics to communicate with the camera, so you'll have to shoot in the manual exposure mode without any assistance from the camera's exposure meter. You can review photos and use the histogram to fine-tune the exposure.
You're probably going to want to use a tripod to hold the camera steady. The lens is long enough, magnifying even the slightest camera movement, and heavy enough that it's almost impossible to hand hold.
Jul 14, 2011 | Rokinon 800mm f80 Lens
My husband pulls tractors at night at tractor pulls, everytime I try to get a picture its too dark, the lighting around the pull isn't the greatest but it has some light
There are several solutions to taking pictures in the dark or low light. Night time photography can be difficult without a tripod. There are three ways you can get a brighter photo
1. Larger aperture - Make sure the aperture is set to the lowest f-stop for the largest aperture. f/2.8 or f/5.6 depending on your lenses capabilities. Choose the lowest number
2. Longer shutter speed - A longer shutter speed will allow more light to hit the canera's sensor and create a brighter picture. Unfortunately with a longer shutter speed, you will probably need a tripod because the photo will come out motion-blurred otherwise.
3. Higher ISO - A higher ISO will make the camera's sensor more sensitive to light and therefore creating a brighter picture without having to have a longer shutter speed. High ISO, however, can introduce unpleasant noise/grain to a photo.
If you want to take your picture while holding the camera in your hands, I recommend the largest aperture (small f/stop) and a high ISO.
If you have a tripod, use it! and use a longer shutter speed since the tripod will hold the camera steady for you.
Jul 09, 2011 | Nikon Cameras
Currently I have a Nikon F65 non-digital camera with 28-80mm lense. I am planning to buy a Nikon D5000 DSLR. My Question: If i buy a Body on D5000 and will be able to use my f65 lenses? Will there will any...
If anything, you will gain image quality because the sensor on the D5000 is smaller than a frame of 35mm film. Thus you will only be using the central portion of the lens. On the D5000, the 28-80mm lens will act as a 42-120mm would on the F65.
However, you will lose autofocus capability. The D5000 does not have a focus motor in the body, relying on the lens having the motor, and neither version of the 28-80mm lens has a focus motor. The lowest-end Nikon dSLR with a focus motor is the D90.
Feb 07, 2010 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
Jun 22, 2009 | Nikon 10.5mm f/2.8G ED-IF AF DX Lens
Nikon D5000 Digital Camera Logo
272 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
