Question about Kenmore 22642 Top Load Washer
Water will not turn its self off and runs over top and floods floor
Need to take the control panel off and blow throu the presure hose and make sure it is clear .
after you do that put the washer on spin for 2 min the try to fill up on small load if that does not work then u need a presure swithch or a new presure line check for craks on the hose going to the tub
Posted on Mar 22, 2011
F&p iw712 floods
Check around the boot at the front of the door. It only takes a hair to get stuck and there will be water everywhere. Or it may be the gasket around the filter cap (if there is one).
Oct 22, 2013 | Washing Machines
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Wont stop filling up with water
1. if the water is not flooding the floor, then you have a drain hose siphoning problem. raise or loop the drain hose up in the back of the machine higher than the highest water level of the machine.
2. if water is flooding the floor and the only way to stop it is to shut it off at the fawcet then the water valve is bad and needs replacing
Jul 01, 2010 | Whirlpool LSR5232L Top Load Washer
Admiral top loading washing machine overflow water
Most likely the water level sensor - check www.repairclinic.com
Jul 31, 2009 | Washing Machines
Water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Jun 18, 2009 | Kenmore 22422 Top Load Washer
99 boxster sometimes get flooded
The drain plugs under the rear convertable top sometimes get clogged with debris. When these drain plugs get clogged the water will run into the car and flood the floor boards. The best way to get to the drain plugs is to open the top halfway. Then walk to the rear of the car and look under where the rear top covered. There is are two drain plugs that are above each rear wheel well.
May 02, 2009 | 1999 Porsche Boxster
1994 Jeep Grand Cherokee Water leaks
It is most likely leaking from the windshield and running down to the floor. Good luck and dont forget to rate
Mar 23, 2009 | 1994 Jeep Grand Cherokee
Portable Whirpool washer, floods the floor when in use
dose it stop flooding when you stop the timer or turn off the water.if timer your presure switch hose has come off.have to empty washer to reinstall because water in tube gives false reading.if when you turn off water its your water level switch.God bless,tom
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The water supply to my my 2004 Maytag Neptune TL top loader will randomally not shut off, casuing the washing machine to file up to the top overflow and flood my first floor. At first it was thought that...
You have several possibles problems
The pressure switch could be faulty or the tube that runs from the pressure switch down to the accumualtor could have a cut or tear in it. solution replace hose.
or The mixing valve could be hanging open also with a piece of debris. solution replace mixing valve
For now turn the water when your not using your machine.
May 19, 2008 | Washing Machines
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
Kenmore 22642 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
