Question about NordicTrack E4000 Treadmill
When I turn on my nordictrack e4400 it runs for 1 second and then stops
  • NordicTrack Master
  • 6,694 Answers
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Posted on Mar 22, 2011
  • garyf832 Mar 22, 2011
    do I replace the whole computer board?
  • Electro Med Services
    Electro Med Services Mar 23, 2011
    hi,
    Before going to replace the controll board. just check the speed sensor. if the speed sensor is faulty the controll board will not get the information of the RPM of the motor. The speed sensor counts the RPM of the motor and send the same to the contoll card. If the controll card will not get this iformation it will stop the motor. You can see tthe spped sensor near motor pulley. It will have two or four wire running from it , which goses to the control card on the top.
    Just remove the speed sensor and clean it well. Refix it and start the treadmill and check is it working or not. Remember one thoing before removing the cover of the treadmill be sure to remove the power from the wall outlet. ok
NordicTrack Treadmill Summit 5500 starts normally and runs about 5 minutes then stops, console lights remain on. Unplug safety key and plug back in, starts and runs another 5 minutes and stops ----.
there 3 things that you observe:
1) The walking belt is too Tight, the deflection will be 2-3" when you lift with his finger.Adjust the https://www.youtube.com/watch?v=XyPedy7HtzM
2) the thermic swithc of the motor Tripp for the tension of walking belt.
3)the driving belt of belt motor too tight. Deflection will be 1/8" loose the bolts of motor, and adjust.
Blessing.
cuadra2016@yandex.com
whatsApp:+50588611441
Oct 31, 2017 | NordicTrack Exercise & Fitness
I have a running machine Nordictrack T7.0. It was running fine But now When I press go it runs fine for 10- 20 seconds and stops. Can I please ask your advice on this? Thanks
Hi There, Speed sensor too far from front roller or defective? Lower control board not reaching target "set-speed" when compared to roller feedback may be a failing lower control board. Good Luck
Apr 16, 2017 | NordicTrack Exercise & Fitness
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
I have a problem. Every time I try to run my treadmill the motor runs for roughly 2 seconds and then turns off. The power is still on, however, but the treadmill only runs in short bursts. How can I f
If it stops but you can still hear the motor running then I would check the belt tension. The force of you running could be causing the belt to stop but no the drive.
Dec 24, 2014 | Nordic Track Nordictrack C2100 Treadmill...
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Belt moves for split second then stops
1= Not rexactly, however you must LUBE the deck belt, this a problem because of lack of maintenance, probably a deck worn, this cause enough friction shut down the machine for protection electronic.
2)LUBE the rollers bearing.3)test the input voltage motor, if there are the motor need repair.4) measure the output voltage board, if there are NOT voltage, the board is faulty, see my personal TIPS, and see the block diagram. RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jul 09, 2012 | Nordic Track NordicTrack A2350 Pro...
Hi I need a copy of the Nordic Track E4400 owners manual. Do you have any idea where I can get one? Please let me know. Thank you
Please go to the next web page: free download
Http://fitness.manualsonline.com
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA
Oct 29, 2011 | Nordic Track NordicTrack Treadmill, A2550
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack E4000 Treadmill Logo
862 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
