Question about IBM ThinkPad T20 2647 Notebook
T20 black screen crash
My T20 suddenly "died", black screen, 1 diode shining. After a certain time, it can be started again, than is working cca 8min and than dies again. When started again immediately after this, it does not start or does the same after a short time. No beeping on start. Fan assembly looks OK, fan is shortly working on start. This is with W2K, but Linux live CD is the same. According to MobileMeter CPU temp is 39oC, HDD 41oC. Please any suggestion? THX a
lot.
    Genius:
  • 2,028 Answers
This could be a problem with the memory. Try removing the memory and starting & running one chip at a time in both slots one at a time. If it turns out that the memory and slots are good, then this will be a motherboard component. Componenet problems can be tricky to track down, even for veteran professionals, so I suggest taking it in for a professional diagnosis.
Posted on Aug 05, 2008
How to ged rid of a black square block in the corner of my screen
If you have an LED television that stands for light emitting diode if all of your light emitting diodes or working then you'd have your total television screen if you have black in a television screen that usually means that the light emitting diodes have died
Feb 07, 2018 | Televison & Video
Hi, my asus f3sc display card crashed due to the fan problme i guess. When i was working, the screen suddenly went black, and it halted. Then i tried to start again. It's starting, but nothing comes on...
if the card crashed then the whole computer would crash, also if the graphics card has died the computer wouldn't boot into windows because it wouldn't pass the POST (Checks if RAM/Graphics card {as well as some other things} are working correctly before booting into windows)
sadly there is no way of replacing a dead graphics card in a notebook without a massive chance of destroying your motherboard, i'd recommend contacting the manufacter and find out if you are still inside warrenty to get a replacement.
Mar 20, 2011 | ASUS F3SC-AS127E-TM T7300/2.0/160/15/VBU...
My 96 STS won't start!
You may have corrosion on the battery terminals. Remove the negative cable first, then the positive. With a special wire brush (made for the purpose and fairly cheap), clean the connector interiors and the post exteriors. If the connector bolts are badly corroded, you can find spares at the auto parts supply where you got the cleaning brush. Apply anti-corrosion grease (from the parts house) to both posts and terminal interiors. Reinstall the positive terminal first, then the negative. Be sure to wash your hands after this to prevent mysterious holes in your clothes. If the battery is discharged, recharge it overnight with a low amperage charger. Take the car to the parts house and have them check the operation of the alternator after you get it running. Hope this helps.
Nov 20, 2009 | Cadillac STS Cars & Trucks
N64 won't yurn on
Well i had a similar problem with my N64 console thats 14 years old so I tried a new expansion pack in it and it worked again. It could just be that then.
May 22, 2009 | Nintendo 64 Console
Acer crashed and coming up with 2 options and black screen
If its on a reinstall click repair the first time and it will take you to Recvovery Console and a command prompt and then type fixboot..
that will fix your boot record and you may not have to do a complete reinstall. If it does not work then start reinstall again and just install normally. Please rate this solution.
Mar 29, 2009 | Acer Aspire 9500 Notebook
Toyota Prius starting problem
There's a known problem with the early Toyota Prius (2001 - 2003), when running the engine for a long period of time without moving or when the car is driven only for short trips (short city driving), the Prius might not start.
You have to change the original battery with a 356 CCA which is bigger because the battery is bigger you also have to change what is holding it into place.
Jul 22, 2008 | 2003 Toyota Prius
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
Screen blackout
Just replace the LCD.
Nov 06, 2007 | LG PM-325 Cellular Phone
Laptop troubleshooting
When it turns black take a flashlight and shine it on the bottom of the screen where the start button would be. Look closely and see if you can seen any faint images there. If you do then your backlight is malfunction. That typically is not a self-fix for the typical user. If you don't see anything can you give us some more information. - Are any lights flashing just before or after the screen turn black? - If you restart the computer will it work again? - Will the screen go black even if you are actively working on the computer? If its not the backlight let us know the answer to these questions and we'll continue. As always please don't forget to rate this posting.
Feb 06, 2007 | NEC Versa E120 (VERHDGJ00B00T) PC Notebook
IBM ThinkPad T20 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
