Question about Peavey Electronics Peavey PR15D 15" 200 Watt Bi-amplified Class D powered speaker
Peavey PR15D amplifier board. What is the part number of U5. The IC is damaged and can only read the beginning of the part #. Starts with HC.....
  • Jean-Yves Blaquiere May 27, 2013
    Coud you tell me if the problem was only U5 or if you had to change other parts?
  • Peavey Master
  • 5,603 Answers
You can contact Peavey and they will send you the schematics. If you can tell me a few characters of what is on the chip I might be able to give you a clue. For power amps they often use the LM3886, an eleven lead power amp clamps to a heat sink. For typical small 8 lead op amps the often use 4560's.
Posted on Mar 23, 2011
Hello good morning i have a peavey 2600 power amplifier, each time i try to turn on the amplifier the breaker switch flies what could cause that to happen
A serious power drain caused by a damaged mains transformer, short circuit power supply, shorted output transistors or a leak to earth taking the earth treip out.
Mar 22, 2018 | Peavey Music
Where is the output IC on a Peavey Max 115? I've been researching away, and I'm still stumped.
You might thy going backwards from the output to the IC .have a good light and make yourself a pointer that is nonmetallic which you can track the copper strips on the circuit board without touching them. If you remove this IC from the board, be sure to wear a grounding strap to your hand or wrist, connected to the metal chassis.BE SURE TO REMOVE THE POWER CABLE BEFORE YOU BEGIN! Note the exact way you remove it. The number one pin will have a indented dot on the plastic case. Be sure to reinstall in the correct order. ALWAYS WEAR A GROUNDING STRAP TO HANDLE ANY IC! The static electric in your body can blow certain IC units. You can make you own grounding strap using an old metal watch band, a piece of flexible wire approx. two feet long and an alligator clip to attach it to the chassis. Hope this helps you and I hope I have not confused you.
Nov 03, 2017 | Peavey Music
What is the power supply number for peavey pv 6
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Mar 26, 2014 | Peavey PV6 Mixer
Peavey md iii 16 ch two channels not working limit light fully lit
Operational amplifier ic that if my memory is correct are 4560D, one ic drives 2 channels...
Oct 03, 2013 | Peavey Music
Where 's the fuse for my kb 100/200 watt amplifier
The fuse is INSIDE the unit and if it blows, then there are other damaged components that require going to a repair shop to repair before replacing the fuse.
Aug 14, 2011 | Peavey Electronics Peavey PR15D 15" 200...
How to get a hum out of the speaker and the other is it sounds too low like in a barrel
First thing is to make sure you are using either XLR or TRS balanced cables to connect to these. Also make sure these are powered from the SAME receptacle as you mixer or source... yes you likely will have to run extension cords to do this. When you meet the above requirements, test that the speakers are equal... if one of the symptoms follows the speaker, then we have probably damaged a speaker or have a defect. Get back to us with your findings. DO NO USE unbalanced cables to send audio to these. Unbalnced cables are TS cables like a guitar cable and are NOT to be used for interconnecting. ALSO give more detail on your setup such as mixer, etc.
Aug 06, 2011 | Peavey Electronics Peavey PR15D 15" 200...
I have a Peavey Bandit 112 amp that takes between five and ten minutes to warm up. It use to come on right away. any suggestions?
Take it for repair immediately as there is something that is thermally sensitive and it may cause worse damage with continued use. The problem is LIKELY a broken solder joint. Depending on where it is, it could cause damage to the power amp portion. It OFTEN is at one of the leads to a volume control and those USUALLY don't cause damage, but one can't be sure till it is repaired. These broken joints oxidize and then eventually warm and punch through and the device starts working. You MIGHT want to try wiggling the controls to see if one brings the unit on immediately showing itself as the culprit.
Apr 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Electronics Peavey PR15D 15" 200 Watt Bi-amplified Class D powered speaker Logo
671 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
