Question about Zebra MC75 Wireless Handheld Barcode Scanner
Are there quick keys to get to the alignment screen
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My E330 in water,the touch screen cannot align,how enterinto the system?
The IC(integrated CIrcuit inside your phone is damage since it getting wet.the IC that connect your touch screen and and the main processor is damage,the only way is to change the iC quick possible you can sent to their service center and ask them for tecnical support.i your warranty still not expire,i think they can fix for you..Feel free to ask for their support:)
Sep 17, 2008 | Toshiba e330 Pocket PC
IMATE jAQ aLIGN SCREEN
how to remove align screen
Jul 05, 2008 | i-mate JAQ3 Smartphone
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
Jas jam screen can't align
tap the screen with thumbs very lightly,sounds funny but it worked. then use a stylist after wing recognizes the taps
Jun 10, 2008 | T-Mobile Wing™ Smartphone
Alignment of screen
at the time of alignemnet tap the + mark at place where it exist. it appears 5 times on screen. centre and 2 on top and 2 on bottom
Mar 28, 2008 | HTC Touch P3450 Smartphone
Align screen
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Nov 02, 2007 | Dell Axim X5 Pocket PC
Align screen loop?
best,
Greg
Sep 14, 2005 | Dell Axim X5 Pocket PC
Zebra MC75 Wireless Handheld Barcode Scanner Logo
147 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
