Question about Brother MFC 6800 All-In-One Laser Printer
What does error code 77 mean on a Brother MFC 6800 fax machine?
4 Suggested Answers
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Posted on Apr 08, 2010
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
SOURCE: brother mfc 9700 error 77
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Posted on Aug 03, 2008
I have a brother mfc 6800 and do I need a telephone line on it?
You will need a phone line connected to the MFC 6800. If you have a separate line for your fax number, make sure you connect this line to your MFC 6800. If you have a different ring, but on the same line as your phone number, you'll need to set up your MFC to utilize the distinctive ring (see the manual for setting this up).
Jan 26, 2010 | Computers & Internet
After paper jam am getting error 77
Try this one:
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Hope that helps.....
Aug 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
Getting a error msg 77 ?
Your Heater Thermistor most likely short circuited. It's a $10.00 part, however, you will want a Brother ASC to replace the part as it requires you to take most of the machine apart. Call your local Brother ASC by searching Brother's Website http://www.brother-usa.com/service/default.aspx enter your printer info and your zip code.
Dec 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Program sending address on brother mfc-6800
The settings should be able to be changed one of two ways. Either under fax settings on the printers menu, or under fax settings under the printer properties panel on the computer.
Mar 10, 2009 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC-8500 Fax Error 77
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Jun 13, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC-6800
I Googled and found a thread with the following tip:
>Menu Button * 9 1 (parameter init), and then Menu Button * 9 9 (Full reset)
That worked great for me and my MFC-6800! If it doesn't work for you, here is the thread with many other tips:
http://www.fixyourownprinter.com/forums/laser/26155#35
Dec 17, 2007 | Office Equipment & Supplies
Problems with Brother MFC-6800 not picking up faxes
i want a cd to set up to my computer and he got problem to receive fax in i going to all store to get the catridge i cant get it
Aug 14, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 All-In-One Laser Printer Logo
248 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
