Question about Whirlpool Duet GHW9150P Front Load Washer
If there is anyway i could get a free answer omg it would be appreciated! what does the error code on a whirlpool ht f 21 mean? please help.
  • 8,197 Answers
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Mar 22, 2011
Error code F--21 and it is locked
Hello, welcome to fixya.
Based on your post I understand you have a "F21" error problem with a Whirlpool washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know. This is also the reason it won't unlock.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Jul 21, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Kenmore model 665.9517 code error eof2. What does this code mean?
Actually, that's not a full Kenmore model number.
If you'll check the tag on the unit, it should be 3 digits, a dot, then 8 more digits, such as ###.########.
But the 665 prefix means it's made for Whirlpool for Kenmore and so F2 would mean a shorting membrane keypad.
In some models, the membrane keypad is available separately. This is a bit of a job.
In others, it is not, but the frame can be replaced, and it comes with a new keypad, and is a pretty easy do it yourself job.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 20, 2010 | Microwave Ovens
Whirlpool Duet HT WFW9200SQ/A it has code F21 coming up. I have owned this machine for a year and half, but just out of the blue this code came up - can't figure out what it means.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an f/33 error message on my whirlpool duet washer how do i fix it
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Apr 26, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Our washer has been displaying the codes F21 and
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 24, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Jul 04, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
F 19 error on Whirlpool AWM 8085
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Replace failed component.
Dec 01, 2008 | Whirlpool AWM8163 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
