Peugeot expert 2l hdi wont start when hot - Heating & Cooling
  • joe_mackin Mar 23, 2011
    vehicle wil not start now that it is cooled down injectors + pump have been serviced recently
  • 2,382 Answers
Hi, there is a possibility that you may have a bad fuel pressure regulator and when the engine is cold there is enough pressure being as there is enough opening of the injectors to start the engine, but when warm the injectors open less and you are not getting enough fuel.
Posted on Mar 22, 2011
  • Tunde Autos
    Tunde Autos Mar 23, 2011
    Hi, the fuel filter could definitely be the problem, or it could be a vacuum leak. Also, the wires could be bad as well as the cap/rotor.
Turbo not working on peogeot 407 2l diesel hdi 16v 2007 sport car
Check egr valve system, check turbo boost solenoid, is it hot ? It should be war but not hot. Check turbo waste gate. Remove the black assy that hold the butterfly valves inside that the turbo air hoses connect onto to and make sure they work by sucking on the tubes to activate them, they are sring opened or closed and the engine vacuum system opens or closes them.
Dec 15, 2013 | 2007 Peugeot 407 2.0
What gearbox will fit in a peugeot expert
Best to contact dealer and get correct information .
Jan 19, 2013 | Peugeot Vehicle Parts & Accessories
Need an english manual for Peugot 206 sw hdi 2l diesel
have one but i cannot upload a PDF document ,have a look on a few torrent sites like the pirate bay and see what you can find,
Mar 01, 2011 | Peugeot 604 Cars & Trucks
Wil not start when engine is hot 2l diesel 407 54
most likely..it has air in the system...first check for leaks(fuel leak) even a drop per minute can let air the system
Apr 21, 2010 | 2005 Peugeot 405
Peugeot 307 HDI airbag warning goes on and blleps
common fault defective centralita computer sorry forgotten name in english been in spain too long .When they get hot where car is left in hot sun the lights start blinking ,these cars and citreons suffer from this fault but not often,cure new centralita ,Once vehicle goes to the test and they see it then its about 2000euros to fix because it will not pass without the relevant paperwork and certificates from dealer,Best advice sell it quick before it costs a lot of money to fix
Jan 17, 2010 | 2005 Peugeot 405
Peugeot 406 estate 2l hdi, anti polution light on
it would never be 1000 euros!!!!!!!!!!!! it will be part of the exhaust system it cuts out because its causing pollution
Sep 15, 2009 | 2005 Peugeot 405
Check gear oil on 2l HDi boxer van
if its automatic there should be a dipstick if not the olny other waay is to drop the pan drain it and fill it back up if you have to do that there should be a hole somwhere on to fill it up
Jul 08, 2009 | 1987 Peugeot Liberte
2005 peugeot expert 2.0 hdi turns off?
Sounds like a flakey connector - try hunting down all the connectors you can find under the bonnet. Separate them, spray with WD40 and reconnect. Start at the engine management computer (silver block with fins on and lots of wires coming out). Take great care not to bend pins.
Jun 08, 2009 | 2006 Peugeot 505
Peugeot 306 problem
Thes have a weak point with the pump in the tank. It is under a cap under the rear seat, get someone to turn the ignition on and listen if no noise give it a tap and see if it whirrs, slacken a pipe on the filter and see if there is pressure, if not the pumps are available from factors or on line.
May 04, 2009 | 1987 Peugeot Liberte
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
