The red lights on the ink and the paper keep flashing back and forth and the printer will not work. I finally got an "internal error"?? is there anything I can do without taking it in to be workded on? There are no paper jams, or does no good to turn it off and back on.
    Guru:
  • 571 Answers
Here's what you need to do. Reset the printer by pressing and holding the power button 5-10 seconds. It should turn off. Unplug it from the power outlet and from the computer. Do a power cycle by pressing the power button for 5 seconds (connections should still be disconnected during this process). Plug it back in to the power source and the computer. Turn it on.
Restart the computer. After restarting, test print. It should work. I have tried it a lot of times.
Posted on Mar 22, 2011
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Lockup
You need to do some cleaning on this printer, because that causes it not to work , you can take the parts off from the printer and use alcohol to clean the dirty parts of the printer..
Hope that helps.............
Sep 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
2 lights flashing
What is the flash pattern?
If the red paper light and the red ink light are blinking in an alternating pattern, then you may have a foreign object or piece of paper blocking the movement of the print head. Turn off the printer, open the printer and look for anything in the printhead path. Remove anything that doesn't belong. Some printers have a strip that the print head travels across that can sometimes come out of position. This can be repositioned by moving it up and down as well as forward and back to align in a guide on the back of the print head.
After clearing the obstruction, close the printer and turn it back on. If the error persists, then the unit needs service.
If the red paper light and the red ink light are blinking together and the green power light is off, then the printer has an internal error. Turn it off and then back on. If the error persists, the unit needs service.
One internal error could be the waste ink absorber is full. These pads are below the printhead and absorb ink during cleaning cycles. To reach them is messy and takes disassembling the printer from the top. This may include removing the print head. Pull the pads, blot the ink off them and the places where they fit in the printer. Run clean water over the pads until the water remains clear. Dry the pads (use a hair dryer to speed the process). Then reassemble the printer.
Next navigate to http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp and fill in the model and serial number of the printer (as well as the other required information). You will get a link to download a reset utility for Windows. Run this tool to solve the error. Do not run this utility until the pads are replaced or cleaned; waste ink will get everywhere inside the printer and over your documents.
I hope this helps.
Nov 19, 2010 | Epson Stylus C86 InkJet Printer
I keep getting a service error B200, and the lights flash green and orange alternately. How can I fix this?
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Jun 07, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Error Code
May 27, 2008 | Canon PIXMA MP470 All-in-One Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 printer flashing lights
then you , like the printer are stuck? well, then open it up, inspect it closely, and find the little paper that is inside and making it flash red..
k24674
jasbo
jasbo
