Question about Kenmore Professional Style 57810 Kitchen Hood
Model #57810 - KENMORE Professional 36" Range hood We recently installed our new range hood but it won't turn on...no lights, no fan. We have it wired properly and it is getting power. Any ideas? Does this model have a fuse?
5 Suggested Answers
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
zeusfaber
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Posted on Apr 05, 2008
  • 5603 Answers
SOURCE: fan comes on by itself in a kenmore 55598 rangehood
I would suspect moisture has gotten into the switch. You may have to replace the switch if the innards have degraded.
Posted on Sep 15, 2009
  • 4 Answers
SOURCE: I have a viking Professional range hood. While
FLASH covers a multitude of possibilities. What is the voltage of the blower motor. What you are describing often happens when 220 is wired to a 110 lighting circuit. I would not be running the blower motor although I hope it has inherent built in motor protection. If the voltage is applied higher to light bulbs they become flash bulbs. Florescents can become fire fixtures fast. If you are not an electrician back away from this and disconnect power at your breakers. Do not open up and trouble shoot if you are not qualified so you do not get embarrassed and have a dirt nap. It only takes about 40 vo;ts and a few milliamps cross chess to kill you. Also when ever you turn something on start and keep the habit of using one hand to turn it on and one hand to grab your pants behind you. OK OK or skirt. This prevents a cross chest shock . Old Navy (USN) death defeating rule that sved me many times and still. Remember call a pro when you do not know .
Posted on Dec 04, 2009
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Exhaust fan just installed not working
Did you have it professionally installed? I would suggest contacting the manufacturer to see if the issue is under warranty. You can find the support page here: http://www.lg.com/us/support-product/lg-LSVC302ST#
Dec 23, 2013 | LG Studio Series LSVC302ST
Kenmore range hood model 31093. The fan motor sounds like its running but the blade is not turning. The blade turns freely when swith is off.
The fan shaft is stripped out inside the hub of the fan...this is fairly common and can be tough to fix...some hubs can be "egg"shaped with a large pliers to make them grip the shaft...
Others I have jammed a small piece of metal in to make them grip...
Also have glued some together with a glue like an expoxy cement that will get hard and hold everything together...
Each one I view and do differently depending on what I find and what's available...
heatman101
Jan 12, 2011 | Kenmore 36 in. Updraft Range Hood with...
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Jul 05, 2009 | Kenmore 51840 Kitchen Hood
Kenmore elite 36" downdraft dimensions
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Mar 11, 2009 | Kenmore 59940 Kitchen Hood
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
A.
Apr 05, 2008 | Kitchen Ranges
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Kenmore Professional Style 57810 Kitchen Hood Logo
41 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
