Question about Sony Handycam DCR-HC48 Mini DV Digital Camcorder
Sony handycam will not open tape tray - Sony Handycam DCR-HC48 Mini DV Digital Camcorder
    Problem Solver:
  • 15 Answers
The spring inside may not be sensitive. Try not to break open as you do not want to break teh mechanical arm and try to push the tray gently in the "spring". The tape will come out eventually
Posted on Mar 22, 2011
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
silly girl
  • 513 Answers
SOURCE: Sony Handycam DCR-PC1E
I'm not from the UK so can't help you find a lab. but regarding your problem - The fact that it works well without a tape tells us that the load motor and possibly even the capstan motor and associated mechanisms are working. It doesn't tell us much about anything else though. Could be that the head drum is not spinning - This can be the result of a siezed drum motor, or power supply fault(if seized it will draw excess current, thus giving a battery warning indication). A faulty, or possibly even a correcly working dew sensor - This will allow the heads to spin, but prevent the tape from actually lacing up. This is a 'hard' one really, because if the dew sensor is faulty you will get this problem, but you will get the same problem when the sensor is working and actually doing its job in that it has really detected moisture. There are many other possible causes too. The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop. Platano guatemalteco? Good luck!
Posted on May 29, 2006
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
Posted on Jun 11, 2008
SOURCE: my camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Posted on Apr 26, 2009
SOURCE: I have a Sony DCR-TRV250 Digital Handycam
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Posted on Nov 17, 2009
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
CAMCORDER'S TAPE IS STUCK, WHEN I PRESS EJECT, THE OUTER COMPARTMENT OPENED BUT THE TAPE COMPARTMENT DID NOT. IT WILL NOT GO DOWN ALSO?
You might have a sony handycam? If so, it is a manufacturers problem that came with the camera. Mine does this all the time, just slap the outside of it and it works. I know it sounds harsh - only do this if you have a sony handycam.
Sep 25, 2009 | Sony 8mm Stantard Grade 120 Minute...
I have a sony Handycam videoHi8 camcorder, my problem is that it
Try using different tape or a new tape in the Camcorder.
Clean the video heads using the Sony V8-25CLD cleaning cassette.
You may also try pressing and holding the Reset button for 30 seconds to reset all the settings in the unit to the factory defaults.
Good luck!!!!!!!!! !!!!!!!!!
Sep 19, 2009 | Sony Video Cameras
When opening camera to insert tape,tape tray slides out,does not
This is new for a sony camcorder technician. Here is what you should do. There may be a sticky substance holding the side tape door to open then the whole tray will go back down. Using battery, press the eject button when the tray is all the way up, disengage the battery to turn the power off. This way you will have the tape tray at posititon just before the opening of side door. With you finger nudge the door outward to see if it is just got stuck by substance. Using Q-Tip with some "windex" go around the edges of the tray. You can also take the door off by removing two screws. -James. For additional assistance by email, go to www.camerarepairjapan.com
Apr 02, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
My handycam sony steady shot , the tape deck will not open
Try using the battery charger while attempting to eject it. The battery, although you may not know it, probably cannot supply the power needed to open the tape deck. If it makes a little Ding sound when you press the eject button, that means it is trying to eject the tape. Hope this helps!
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
My camcorder tape door won't close
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony Handycam  DCR-HC48 Mini DV Digital Camcorder Logo
149 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
