Question about GE Heating & Cooling
HAVE A VERY OLD CENTRAL AC UNIT NOT COOLING. DO YOU YOU WHAT COULD BE WRONG
    Genius:
  • 1,033 Answers
Hello, usually when a air conditioner does not cool it falls into a airflow problem or a low refrigerant charge. The first thing to check is the condition of your air filter, blower wheel, and evaporator coil make sure they are clean. If that checks out good then most likely your air conditioner has a low refrigerant charge due to a leak. In this case you will need a technician to come out and repair the leak.
Posted on Mar 22, 2011
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Carrier central AC/Heat system repeats "Replace
Try unplugging the unit and waiting a few which many times resets the board.
Aug 03, 2011 | Heating & Cooling
I have a 2 ton central unit for my upstairs. It is 25 years old and still runing. Lately it will run all day when the outside heat is peaked and then when dark falls it will catch up at about 10:00pm and...
Hello, it could be that the unit is slightly undercharged and has a small leak. Usually when the cooling is needed the most the ac wont be able to keep up with the heat load as you mentioned.
Jul 15, 2011 | Ruud UAPA042 Air Conditioner
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 09, 2017 | Heating & Cooling
Cooling problem with my ac.
The start capacitor may be the problem. Is your AC a central unit or window unit? Whats the model and make? If a window unit it could also be the thermostat is defective or too close to evaporator fins. Dirt on the condenser outside can cause the motor to heat up to the point it shuts down to cool the internal overload. Let me Know, Sea Breeze
May 18, 2009 | Carrier Heating & Cooling
Ac unit not turning on
Chances are your A/C unit can be repaired for a lot less than a new one -- I'd call for service.
May 07, 2009 | Heating & Cooling
My Central AC Unit is leak
There is a drain system on all A/C system cooling coils. Your drain is restricted or plugged. Finding the outlet you can blow back through it to dislodge an obstruction. Alternative is to replace the drain tubing or piping.
May 26, 2008 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
