Question about Craftsman Garden
My chainsaw will start on choke but dies when you give it gas
  • 2,510 Answers
You need to strip and clean out the carb. The main fuel passages and jets are blocked or stuck. A new gasket set would probably also not be out of place.
Posted on Mar 22, 2011
3 Suggested Answers
SOURCE: Chainsaw runs, but dies when given gas.
Check the fuel line for cracks. That is usually the problem. Plastic fuel lines crack with age and need to be replaced. I have had a couple of Craftsman Saws (made by Polan do the same thing).
Fuel line can usually be purchased at a hardware store or saw shop. Takie a piece of the old line with you to get the right size.
Dan
Posted on Jan 07, 2009
dontbother10
  • 2220 Answers
SOURCE: My Poulan Pro 260 chainsaw will start and run when
It is running in a lean condition. Continued operation like that can cause piston and cylinder failure.
I'd take it in for repair estimate ($10) at the local chainsaw seller/mechanic. Explain the problem you are having, Probably a leaking fuel line. I'd expect a repair and tune up about $40-60. Your saw will perform better and your arm will thank you. If tuned ask what fuel/oil ratio they used (should be 50:1) and affix a label to your fuel tank. HTH
Lou
Posted on Nov 09, 2009
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Husqu51 starts once but dies then just turns over
take off the muffler and try it if ok then open it up and clean the carbon from the screen
Apr 02, 2012 | Garden
Dies when you give it gas
Hayter 48 lawn mower choke engages but but does not start easily and does not not flood when left in choke position
Dec 14, 2011 | Homelite Garden
I have an old stihl 020 av chainsaw, the problem I'm having is when you start it and it's running the as soon as you go to give it gas it want to bog out and die even if you just try to give it alittle gas...
Look for your choke lever and make sure that it is operating properly. When the engine is choked, the butterfly valve in the engine is across the opening, causing the engine to take less air, and more fuel. As the engine begins to warm up, there is less need for the choke to be closed. If your choke valve is remaining closed, the engine will die when you pull the trigger.
Best regards, --W/D--
Jan 31, 2011 | Garden
I have a weedeater and that is thebrand name as well,the weedeater only starts up while in the full choke mode,when I take off the choke and give it some gas it dies everytime?
Likely you have gum buildup or a particle in the jets of the carb. Usually, you have to disassemble and clean, BUT you can try the old trick: pull the air cleaner, run the unit as fast as it can go, using choke or whatever makes it go, and then place palm over intake. Sometimes this will **** the obstruction out.
Sep 26, 2010 | Garden
Chainsaw runs out of gas.
From your description, it sounds like your carb is running too lean. Make sure the spark arrestor screen is free of carbon build-up and the air filter is in place. Warm the saw up. With the saw at idle, adjust the Low adjustment screw to slightly enrich the mixture. If you turn it to run the fastest possible when idling, it is too lean. When the Low setting is right, you will be able to increase the RPM without it dying. If the High setting is way too lean, it may also die when you open up the throttle. If you run the saw too lean, it willl overheat and sieze.
Mar 29, 2009 | Echo Garden
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
150 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
