Question about Alpine SWX-1043D Car Subwoofer
My amp wont come on and it is hooked up correctly... is it possible for condensation to ruin an amp?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
If there is moisture inside of the amp, it can definitely keep it from working. if it remains wet long enough it can cause corrosion of the board and parts.
Posted on Mar 22, 2011
Why does my 2003 chevy venture overheat after ten minutes
Can not guess for an answer
I wouldn't be using any vehicle that overheats
but most folks do & try to ruin the motor
Could be a water pump issue
Could be a thermostat issue
Could be a bad head gasket
Could be a coolant leak
Could be a timing chain issue
Could be worn,damage & blocked exhaust converter
Could be 8" of leaves in between the condenser & radiator
Could be failed & clogged radiator,from someone adding stop leak
& ruining the coolant system
You know all that
Should I keep adding to the list
Jul 14, 2014 | Cars & Trucks
1999 f150 wont shift into 3rd
The transmission is not shifting correctly
& may have been for some time, & you
did not know it
Most likely will have to be rebuilt
Any time you drive even ten miles, when you do
know there is a problem, your can ruin it
Mar 12, 2013 | 2004 Ford F150
I need the wiring diagram for the IAT Sensor in my 2005 Chevy Tahoe. I nned it to hook up one of those cheap little "chips" just to see how it works before I spend $ 300 for a Superchip.
Wouldn't you be better to spend $300 on tools ,reference material,
test equipment or a code reader, than that nonsense & possibly
ruin your vehicle & most certainly accomplish nothing
Learn how vehicles work & how to diagnose them & in 20 years
you can play with a race car or something
Feb 07, 2013 | Cars & Trucks
Why wont my te4001d amp light up?
Did you check the fuses? If they are (Blowin) Condensation will not harm a car amp.It is normal to have condensation on a car amp,When it is cold out. I have been installing car audio Equipment for over 40 years ,End never seen a amp that was damaged buy condensation on it.
Oct 19, 2012 | MTX Te4001D Thunder Elite Monoblock...
My subwoofer powers on, but I get no sound out of speakers or subwoofer and all of connections are correct.
First off....never connect a speaker when the amp is on or vice versa. Second, I would get a tone generator and test that the speakers have not been ruined and check the amp to make sure you did not blow that. Most amps have a protective circuit to prevent damage from over heating or hooking up wrong. Also make sure that you have enough output wattage for the way you have them wired..
Mar 16, 2012 | Aspire Digital AD-150PSC Subwoofer
I have a Brother PE 770. All was well, fairly new machine and whipped stitches out correctly. All of a sudden it is shredding the top thread and it almost seems the bobbin is not catching. Would this be...
here are some suggestions to try
it's may be the needle, it could be bent or blunt
it is possible that it could be the timing,,,, but first try changing the needle & try rethreading the
machine the top thread & bobbin also
make sure the bobbin is in the bobbin case correctly & that the bobbin case is correctly inserted into the machine correctly
check to see if there are any burrs on the needle plate
clean out from under the needle plate
also make sure the bobbin area is clean from lint or loose threads
Oct 18, 2010 | Brother PE770 Computerized Sewing Machine
Haier HRF10 what would happen to the fridge without condenser
it could but the possibility is low but you willl ruin the ref doing that
Jun 29, 2009 | Haier HRF10 Top Freezer Refrigerator
Install two 10" subwoofers in a 2002 grand am monsoon.
The only way to Correctly do this is to Run an External Amp for your Subs. If you continuously run the Subs off of the Factory Amp It will Ruin the Subs and the Amp Eventually. This way you can still Connect the Rear speakers as they need to be. Please Rate my solution, I need all the Help that I can Get! Thanks!
Jan 26, 2009 | 2002 Pontiac Grand Am
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Alpine SWX-1043D Car Subwoofer Logo
37 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
