Question about Refrigerators
I have a Kenmore 363.9537813 side by side refrigerator. My "DE" flashes continuously. Last week it did the same thing and my freezer had a lot of build up in it and stuff began to thaw. I emptied the unit and turned it off and allowed it melt. turned it back on and it worked fine.No DE flashing.. A week later its flashing DE again. I don't see any ice build up and the contents are still frozen for now.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Posted on Aug 05, 2007
SOURCE: Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Posted on Sep 15, 2008
  • 1218 Answers
SOURCE: drain tube always frozen...ice build up in freezer
Good day,
The first step is to defrost the machine completely.
The second step is to clean the drain properly. Service techs use compressed air to blow the lines clean. This is followed by pouring extremely hot water onto the drain pan below the evaporator. mixed with a little bleach, to flush any junk left over.
The reason for the extended shut down, is ice will build up under the pan below the evaporator coil, and if not melted and dried out will cause the problem to re-appear in a short while.
Shut down (unplugged) should be a minimum of 12 hours. 24 better.
A real pain, but is the best long term solution.
Posted on Nov 28, 2009
Testimonial: "i'll give that a shot.............thanks"
  • 1244 Answers
SOURCE: ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Posted on Jan 13, 2010
My kenmore side by side frigerator section part froze all the items like milk etc then we turned the thermostat down and it seemed to slove the problem for a couple of weeks then today we see the freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Kenmore Side by Side Refrigerator
Kenmore Side by Side, hear a clicking sound every 10 mins. or so; freezer starts defrosting several times a week then freezes again. What is the problem?
heatman101
Mar 20, 2011 | Kenmore Side by Side Refrigerator
Fan seems to be running continually but not cooling (fridge or freezer) settings are set at factory settings
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 26, 2010 | Kenmore 56729 Side by Side Refrigerator
Freezer temp is up to 25 degrees and it's flashing "service"
Refrigerator
heatman101
Dec 07, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refrig and freezer not cooling and "clicks" at
heatman101
Nov 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
